FORScan 2.3.40 Released
2.3.40 beta, 2021-04-21 (download)
- Vehicle database update
- Support SYNC4 Module Configuration functions
- Many new configuration parameters for different modules and models
- Configuration and Programming function “Transmission Characterization Update” for:
Transit (North America) 2020 model year - Configuration and programming function FSC “Module initialization/relearn from Central Configuration” for:
Mazda 3/CX-30 2019+model year - Service functions PCM “Reset All Adaptations” (KAM reset), “Clear Transmission Adaptive Tables”, BCM “Local Interconnect Network New Module Calibration”, “Tire Pressure Monitor learning mode”, “Battery Monitoring System Reset” for:
F-150 2021 model year - Service functions EPB “Apply and Release Calibration (Assembly Test)”, “Enter Electric Parking Brake Maintenance Mode”, “Exit Electric Parking Brake Maintenance Mode”, “Apply Electrical Parking Brake”, “Release Electrical Parking Brake”, “Apply left EPB actuator”, “Release left EPB actuator”, “Apply right EPB actuator”, “Release right EPB actuator” for:
F-150 2021 model year - Service function “Rmode Rebalance” (battery rebalance) for:
Fusion 2.5 HEV 2010-2012 model years
Lincoln MKZ 2011-2012 model years
Mercury Milan 2.5 HEV 2010-2012 model years - Service procedure PCM “Reset oil change indicator” for:
Ecosport 1.5 DV5D 2018 model year
Ka/Figo 1.5 DV5D 2018 model year - Service procedure PCM “Low Pressure Fuel System Prime” for:
Focus Mk4 1.5 TDCi 2019 model year
Transit Connect 1.5 TDCi 2019-2020 model years - Service functions FSC “Static aiming”, “Dynamic aiming” for:
Mazda 3/CX-30 2019+MY - Service functions for ABS/ESP module: “Calibrate Lateral and Longitudinal Acceleration Sensors”, “Calibrate Steering Angle Sensor” for:
Ranger 2011 model year
Mazda BT-50 2011 model year - Service functions for ABS/ESP module: “Calibrate Lateral Acceleration Sensor”, “Calibrate Longitudinal Sensor”, “Calibrate Pressure Sensor”, “Calibrate Yaw Rate Sensor” for:
Focus Cabriolet 2006/2008 model years
Focus Mk2/2.5 2003-2010 model years
Kuga Mk1 2008 model year - Service procedures PCM “Low Pressure Fuel System Prime”, “Reset the Low Pressure Fuel System Learned Values”, “Reset the Turbocharger Variable Vane Position Sensor Adaptation”, “Reset the Turbocharger Accumulated Soot Value”, “Reset pilot injection quantity learned values - Cylinder 1…4” for:
Galaxy/S-Max 2.0 TDCi 2015 model year
Mondeo Mk4 2.0 TDCi 2015 model year - Service procedures PCM “Reset the Water In Fuel Warning Indicator”, “Reset the High Pressure Fuel System Learned Values”, “Reset Crankshaft Position Sensor Adaptation”, “Reset the Cylinder Balancing Adaptation”, “Reset the Low-Pressure Fuel System Learned Values” for:
Transit Connect 1.5 TDCi 2019-2020 model years - Service procedures PCM “Reset the Water In Fuel Warning Indicator”, “Low Pressure Fuel System Prime” “Reset the High Pressure Fuel System Learned Values”, “Reset MAF Sensor Adaptation”, “Reset the Low-Pressure Fuel System Learned Values” for:
C-Max 2.0 TDCi 2015 model year - Service functions TCM “Shift Fork System Learn” and “Clutch System Learn” for Powershift DCT450 for:
C-Max 2.0 TDCi 2015 model year - some missing OBDII Mode 6 tests for Mazda
- “Check and update adapter’s firmware” checkbox to Settings->Connection (was previously only available for v2.4)
- improved support for 2021MY models (F-150, Transit North America, Transit Connect, some Mazda 3)
- problem accessing IPC module configuration p/n ML3T-10849-B* (F-150 2021)
- incorrect reading module As Built Data in some cases
- bug in Configuration and Programming function “Transmission Characterization Update” for some new models with 10R transmissions
- bug of missing Central Configuration functions for Galaxy 2010MY (appeared in v2.3.39)
- bug of missing IPC configuration parameter “Trailer Brake Controller Gain Setting” in F150 2015+MY and some other models
- bug of incorrect calculation some parameters, like Mazda VTact, VTdiff (may be some other parameters as well)
- small visual bug in “TCM Adaptive Learning” service function: displaying error “…cancelled by operator” on normal exit
