FORScan 2.3.45 Released 2022-01-16 (Support for SYNC4 retrofit)
2.3.45 release, 2022-01-16
(download)
Release notes:
Added feature
  • Vehicle database update
  • New configuration parameters for different modules and models
  • Service functions PCM “Clear Transmission Adaptive Tables” for:
    Expedition 2018-2022 model years
    Explorer 2020 model year
    F-Series 2020-2022 model years
    Lincoln Aviator 2020 model year
    Lincoln Navigator 2018-2022 model years
  • Service functions PCM (were announced in v2.3.8 but it seems wasn’t really added or got broken in some later release) “Reset EGR Valve Adaptations”, “Camshaft Position Reference Adaption Learn”, “Reset the Low Pressure Fuel System Learned Values”, “Reset the Turbocharger Variable Vane Position Sensor Adaptation” “Reset pilot injection quantity learned values - Cylinder 1…4” for:
    Focus Mk3.5 2.0 TDCi StgVI 2015 model year
  • Service function PCM “GPF static regeneration” for:
    Fiesta 1.5 Dragon 2017 model year
  • Service function TRCM “Shift Cable Adjustment Mode” (requires adapter with electronic switching between HS/MS, also workshop manual) for:
    Fusion 2017-2020 model years
    Mondeo China 2017-2020 model years
    Lincoln Continental 2017-2020 model years
    Lincoln MKC 2015-2019 model years
    Lincoln MKX/Nautilus 2016-2018 model years
    Lincoln MKZ 2013-2020 model years
  • Service function ABS “ABS Service Bleed”, “Calibrate AdvanceTrac/IVD” for:
  • Service functions ABS/EPB “Apply and Release Calibration (Assembly Test)”, “Enter Electric Parking Brake Maintenance Mode”, “Exit Electric Parking Brake Maintenance Mode”, “Apply Electrical Parking Brake”, “Release Electrical Parking Brake”, “Apply left EPB actuator”, “Release left EPB actuator”, “Apply right EPB actuator”, “Release right EPB actuator” for:
  • Service function BCM “LED Lamp and Lamp Driver Module Initialization” for:
    Explorer 2016-2019 model years
    Lincoln MKZ 2017-2020 model years
  • Service functions BCM “Local Interconnect Network New Module Calibration”, “Tire Pressure Monitor learning mode”, “Battery Monitoring System Reset” for:
    Maverick 2022 model year
  • Service function CCM “Calibrate Cruise Control Sensors” for:
    Ranger 2018-2021 model years
  • Service function IPMA “Lane Departure Warning System Camera calibration” for:
    Explorer 2020+ model year
  • Service function SASM “Steering Wheel Angle Trim”, “Steering Motor Angle Trim” for the following vehicles with adaptive steering:
    Lincoln Aviator 2020+ model year
  • Service functions VDM “Suspension Temperature Calibration”, “Ride Height Calibration” for the following models with the pneumatic suspension:
  • Service functions HVAC “Actuators Calibration”,“Reset the Outside Air Temperature Sensor Learned Values” for:
  • Service function TCU “Module Service Provisioning” (to authorize TCU in FordPass application, experimental!) for:
  • Test BECM “Show Battery Cell Voltages” for:
    C-Max 2.0 FHEV/PHEV 2013-2018 model years
    Focus Mk3/3.5 BEV 2012-2018 model years
    Fusion 2.0 FHEV/PHEV 2013-2020 model years
    Mondeo China 2.0 FHEV/PHEV 2017-2019 model years
    Mondeo EU 2.0 FHEV 2015 model year
    Lincoln MKZ 2.0 FHEV 2013-2020 model years
  • Support SYNC4 (retrofitted) for:
    F-150 2016-2020 model years
    Fusion 2013-2020 model years
    Mustang 2015-2020 model years
Improved/changed feature
  • improved support of some J2534 adapters (fex. Mongoose-Plus Ford2)
  • improvement in Configuration and Programming function “Transmission Characterization Update”: if server returns error on downloading the strategy file, show this error message to the user
  • improved support for 2021-2022MY models (Expedition, Explorer, Mach-E, Maverick, Bronco Sport, Lincoln Aviator, Lincoln Corsair)
  • improved algorithm that detects module calibration level.
Bug fixed/removed feature
  • Service function PSCM “Calibrate Steering Angle Sensor” for Explorer/Aviator 2020 (isn’t really supported by module)
  • bug in the configuration and programming function PCM “Vehicle ID (VID) block configuration”: unability to write VID anymore after successful first write
  • bug in the configuration and programming function IPC “Odometer Write” function for Kuga 2017-2019 model years (function was unable to write the mileage)
  • bug in RCM service function “Crash Flag Reset” for Mondeo Mk4 2007 model year
