FORScan 2.3.56 Released 2023-09-07
2.3.56 release, 2023-09-07 (download)
  • Vehicle database update
  • New configuration parameters for different modules and models
  • Configuration and Programming function AWD “Active Torque Coupling (ATC) Configuration” for:
  • Bronco Sport 2021 model year
  • Explorer 2020 model year
  • Lincoln Aviator 2020 model year
  • Service functions PCM “DPF Static Regeneration”, “Reset the Diesel Particulate Filter Learned Values”, “Read Fuel Injector correction factors”, “Change Fuel Injector correction factors” for:
  • F-Series 2023 model year+ PCM, CCM, IPMA, BCM, IPC service functions for:
  • Mustang 2021-2023 model years
  • Service function CCM “Calibrate Cruise Control Sensors” for:
  • Mach-E 2021-2023 model years
  • Service procedures IPMA “Local Interconnect Network New Module Calibration”, “Rear Camera Calibration”, “Lane Departure Warning System Camera calibration”, “Pro Trailer Backup Assist Camera Calibration”, “360 degree View Camera Calibration” for:
  • Mach-E 2021-2023 model years+ Service function BCM/BdyCM “PATS Programming” (only erase and program keys function, no module initialization, experimental functionality) for:
  • Galaxy/S-Max (Europe) 2015 model year
  • Edge 2015-2020 model years
  • Escort 2015-2018 model years
  • Everest 2015 model year
  • Explorer 2016-2019 model years
  • F-150 2015-2019 model years
  • F250…F450 2017-2020 model years
  • Fusion 2013-2020 model year
  • Ka / Figo 2015 model year
  • Mondeo Mk5 (China) 2013-2019 model years
  • Mondeo Mk5 (Europe) 2015 model year
  • Mustang 2015-2019 model years
  • Ranger 2015 model year
  • Transit Custom 2016 model year
  • Lincoln Continental 2017-2020 model years
  • Lincoln MKC 2015-2019 model year
  • Lincoln MKX/Nautilus 2016-2020 model years
  • Lincoln MKZ 2013-2020 model year
  • Service function IPC “PATS Programming” (models with standard ignition key) for:
  • Taurus 2010-2012 model years
  • Lincoln MKS 2010-2012 model years
  • Lincoln MKT 2010-2012 model years
  • Service function IPMA “Lane Departure Warning System Camera calibration” for:
  • Bronco Sport 2021-2023 model years
  • Service procedure RFA “Remote Keyless Entry and Start Programming” (models with push button start) for:
  • bug: missing configuration by solenoid ID option in the “Transmission Characterization Update” Configuration and Programming function for some Mondeo Mk5 versions
  • bug: incorrect PCM configuration for P708 6.7L diesel. Now options such as AEIS and speed limit are managed properly (demanded by many users)
  • bug: “Access Denied” error in PCM “Reset Speed Limit” service function for Transit 2006-2013 model years
