FORScan 2.3.59 Released 2024-03-03
2.3.59 release, 2024-03-03 (download)
Last Version Changes History
Added feature
- Vehicle database update
- New configuration parameters for different modules and models
- Configuration and Programming function PCM “Transmission Characterization Update” for:
- Mustang S550 2021-2023 model years
- Configuration and programming function IPC “Central Configuration” for:
- Mazda 5 / Premacy 2008-2011 model years
- Configuration and programming function ABS “VIN Learn” for:
- Mazda 2 / Demio 2007-2011 model years
- Missing diesel PCM service functions for:
- Focus Mk4 2.0 TDCi 2019+ model year
- Transit Courier 1.5 TDCi StgVI 2014 model year (2014-2023)
- Cylinder power balance test for the following TDCi models (experimental!):
- Focus Mk1 1.8 TDCi 2001/2002 model year
- Mondeo Mk1 2.0/2.2 TDCi 2001 model year
- Transit 2.4 TDCi 2000 model year
- Transit 2.0 TDCi 2001 model year
- Transit Connect 1.8 TDCi 2002 model year
- Service function IPMA “Lane Departure Warning System Camera calibration” for:
- Transit V363 2020-2023 model years
- Service procedure RFA “Remote Keyless Entry and Start Programming” (models with push button start) for:
- Fusion (North America market) 2010-2012 model years
- Mustang 2010 model year
- Taurus 2010-2012 model years
- Lincoln MKS 2009-2012 model years
- Lincoln MKT 2010-2012 model years
- Lincoln MKZ 2010-2012 model years
- Service function “Read Factory Keyless Entry code” for:
- Flex 2010-2012 model year
- Sub-function “Initialize Steering Column Lock” of service function “PATS Programming” for:
- Galaxy/S-Max (Europe) 2015 model year
- Edge 2015-2020 model years
- Escort 2015-2018 model years
- Everest 2015 model year
- Explorer 2016-2019 model years
- F-150 2015-2019 model years
- F250…F450 2017-2019 model years
- Fusion 2013-2020 model year
- Ka / Figo 2015 model year
- Mondeo Mk5 (China) 2013-2019 model years
- Mondeo Mk5 (Europe) 2015 model year
- Mustang 2015-2019 model years
- Ranger 2015 model year
- Transit Custom 2016 model year
- Lincoln Continental 2017-2020 model years
- Lincoln MKC 2015-2019 model year
- Lincoln MKX/Nautilus 2016-2020 model years
- Lincoln MKZ 2013-2020 model year
Improved/changed feature
- improvement: ability to gain PATS access in case of BCM EEPROM damage (in case of battery disconnection, for example) for new PATS
- content change: to avoid misunderstanding, the “Module Reset” function is renamed to “Module Reboot”, additional information is added to the function help page
- improvement in datalogger: BCD data are now displayed as HEX (for example, KEY_3_TIC is now displayed as FA0E766F, previoulsy - as 4195251823)
Bug fixed/removed feature
- bug: incorrect BCM Module Configuration layout for Transit V363 2022+
- bug: incorrect work of some service functions on SIM-28/SIM-29 ECU
- bug: incorrect work of sevice function PCM “Change Fuel Injector Correction factors” for:
- F-Series F-250…F750 6.7 Powerstroke 2020-2024 model years
- bug: incorrect work of sevice function PCM Reset “Crankshaft Position Sensor Adaptation” for:
- F-Series F-250…F750 6.7 Powerstroke 2011-2016 model years
