FORScan 2.3.63 Released 2024-10-09
2.3.63 release, 2024-10-09 (download)
Added feature
- Vehicle database update
- New configuration parameters for different modules and models
- PCM engine service functions for Ranger P703 Ecoboost 2022+ model year
- Some missing diesel PCM service functions for:
- Ecosport 1.5 DV5D 2018 model year
- Focus Mk4 1.5 TDCi 2019 model year
- Ka/Figo 1.5 DV5D 2018 model year
- Kuga 1.5/2.0 TDCi 2020 model year
- Transit Connect 1.5 TDCi 2019 model year
- Automated transmission service functions for:
- Galaxy/S-Max 2015 model year
- Ranger P703 2022+ model year
- Service function IPC “PATS Programming” (models with standard key) for:
- Fiesta (EU) 2013 model year
- Ecosport 2012-2014 model years
- Service function ABS/ESP “ABS Service Bleed” for:
- Puma 2020 model year
- Ranger (North America) 2004-2009 model years
- Mazda BT-50 4.0 V6 SOHC 2007 model year
- Ranger (South America) 2.3 I4 2005/2006/2009 model years
- Service function ABS/ESP “Calibrate Longitudinal Acceleration Sensor” for:
- F-250…F450 2020+ model year
- Service functions ABS/ESP “Calibrate Lateral Acceleration Sensor”, “Calibrate Yaw Rate Sensor”, “Calibrate Pressure Sensor”, “IVD Initialization” for:
- Service function SASM “Steering Wheel Angle Trim”, “Steering Motor Angle Trim” for the following vehicles with adaptive steering:
- F-250…F450 2020 model year
- Added local date check on the license activation (more graceful behavior in case if the computer date is wrong)
Improved/changed feature
- improvement: partially reworked PIDs database for new models (2018-2020+): fixed bugs, content errors, added missing PIDs etc. Note: new vehicle profile has to be created
- improvement in the IPMA “Lane Departure Warning System Camera calibration” function: added special initialization procedure for HEV models. The change is applied for:
- Fusion FHEV/PHEV 2013-2018 model year
- Mondeo (China market) FHEV/PHEV 2017-2019 model year
- Mondeo (EU market) FHEV 2015 model year
- Lincoln MKZ FHEV 2013-2018 model year
- improved security access procedure that previously failed on some ECUs because required timeout hadn’t elapsed
Bug fixed/removed feature
- bug: incorrect work with old Ford ISO 9141 RCM that might cause clean of configuration and airbag lamp panic
- bug: incorrect reading As Built Data in some new powertrain modules
- bug: incorrect graph building for some parameters (PIDs)
