FORScan 2.3.66 Released 2025-05-16
2.3.66 release, 2025-05-16 (download)
  • Added feature
  • Vehicle database update
  • Added support for Ford/Lincoln models of 2025 model year (available in April 2025)
  • New configuration parameters for different modules and models
  • Support for Curl Internet library and new setting to choose Internet API between Curl and Windows (Curl is default setting since now)
  • New connection setting “Confirm the correct identification of the vehicle”. If this checkbox is set, FORScan will ask to confirm that the car is recognized correctly and offer to enter strategy number if not
  • Configuration and Programming function IPC “Odometer write” (can only increase mileage!) for:
    Fiesta/Fiesta 3 Door/Fusion / Ikon (EU) 2006 model year
    Transit / Tourneo Connect (EU, some versions) 2009 model year
    Mazda 2 (EU) 2006 model year
  • Configuration and Programming function PCM “Transmission Characterization Update” for:
    E-Series 2021 model year
    F-650/750 2021 model year
  • Configuration and Programming function RCM “Module Initialization/Relearn Vehicle Data” for:
    Bronco 2021-2025 model years
    Bronco Sport 2021-2025 model years
    E-Series 2024-2025 model years
    Ecosport 2018+ model year
    Edge 2021-2024 model years
    Escape 2020-2025 model years
    Everest (U704) 2022 model year
    Explorer 2020-2025 model years
    Expedition 2018-2025 model years
    F-150 2021-2025 model years
    F-250…F-550 (P558) 2020-2022 model years
    F-250…F-600 (P708) 2023-2025 model years
    Fiesta (EU) 2017 model year
    Focus (EU) Mk4/4.5 2019/2022 model years
    Ka / Figo 2018 model year
    Kuga 2020-2025 model years
    Mach-E 2021-2025 model years
    Maverick 2022-2025 model years
    Mondeo EVOS 2021 model year
    Mustang (S550) 2021-2023 model years
    Mustang (S650) 2024-2025 model years
    Puma 2020/2024 model years
    Ranger (P375) 2018-2023 model years
    Ranger (P703) 2022-2025 model years
    Transit (NA) 2020-2025 model years
    Transit (EU) 2019/2024 model years
    Transit Connect (EU) 2019 model year
    Transit Courier (EU) 2024 model year
    Transit Custom (EU) 2024 model year
    Lincoln Aviator 2020-2025 model years
    Lincoln Corsair 2020-2025 model years
    Lincoln Nautilus 2024 model years
    Lincoln Navigator 2018-2025 model years
    VW Transporter 2025 model year
  • Service function PCM “Misfire Monitor Neutral Profile Correction” for:
    Focus Mk3.5 1.6 Duratec StgVI 2015 model year
  • Service function ABS/ESP “ABS Service Bleed” for:
    Focus Mk1 (C170, C170 SA) 2002-2009 model years
    Ikon 2003 model year
    Transit / Tourneo Connect (V227) 2002-2009 model years
    Transit Courier (B460 EU) 2014 model year
    Mazda 2 (EU market) 2002/2006 model years
  • Service procedures IPMB “Local Interconnect Network New Module Calibration” for:
    Edge (CD391) 2021-2024 model year
  • Function BCM “RF Keypad Identify Devices and Clear Slots” in addition to functions “RF Keypad Learning by Serial Number”, “RF Keypad Learning by 48-char Code” for:
    Edge 2015-2020 model years
    Explorer 2016-2019 model years
    F-150 2015-2020 model years
    F-Series 2017-2020 model years
    Fusion 2013-2020 model years
    Galaxy/S-Max 2015 model year
    Mondeo Mk5 2015 model year
    Mondeo (China) 2017/2019 model years
  • Service function VDM “Ride Height Calibration”, “Suspension Temperature Calibration”, “On-Board Scales - Vehicle Payload Update”, “On-Board Scales - Height Sensor Calibration”, “On-Board Scales - Spring Calibration” for the following models with pneumatic suspension:
  • Last file path for As built files is now remembered after using “Module Configuration (As Built format)”
  • Improved/changed feature
  • fixes and improvements in J2534 communication procedure
  • Bug fixed/removed feature
  • bug: unable to run PATS Programming-> Module Initialization on vehicles that have no key check functionality (like Police Interceptor)
  • bug: incorrect work with ABS module in the “Module Initialization” subfunction of the PATS Programming function on Transit V362/V363 2016+MY, Ranger P375 (vehicle profile has to be re-created! bug appeared in v2.3.65)
  • bug: incorrect work with PCM module in the “Module Initialization” subfunction of the PATS Programming function on Transit 2.2 TDCi 2006-2013 model years (bug appeared in v2.3.65)
  • bug: unable to gain security access to ABS module in the “Module Initialization” subfunction of the PATS Programming function on Transit V362/V363 2012/2014/2017 due to EEPROM error on 20% of ABS modules
  • bug: incorrect work with PCM module in the “Module Initialization” subfunction of the RFA “Remote Keyless Entry and Start Programming” function for:
    Edge 2011-2014 model years
    Expedition 2015-2017 model years
    Explorer 2011-2015 model years
    Flex 2013-2019 model years
    Taurus 2013-2019 model years
    Lincoln MKS 2013-2016 model years
    Lincoln MKT 2013-2019 model years
    Lincoln MKX 2011-2015 model years
    Lincoln Navigator 2015-2017 model years
  • bug: crash FSC Dynamic Aiming service functions on some Mazda cars
  • bug: not complete instruction in the service function ABS “Exit Electric Parking Brake Maintenance Mode” service for Ranger P703 (may lead to incorrect work of the procedure)
  • bug: incorrect handling TRID number small letters in the configuration and programming function “Transmission Characterization Update”
