FORScan 2.3.67 Released 2025-09-18
2.3.67 release, 2025-09-18 (download)
Added feature
- Vehicle database update
- Support for dedicated PCM and TCM OBDII modules instead a single OBDII module (that didn’t work properly in case if several modules supported OBDII)
- Support for ELS27v5 (firmware update, FEPS)
- Configuration and Programming function AWD “VIN Learn” for:
B-Max 2012 model year
Fiesta (EU) 2008 model year+ - Configuration and Programming function SOBDMC “Transmission Characterization Update” for HEV vehicles:
Edge (CDX706) FHEV 2023-2025 model years
Escape/Kuga FHEV/PHEV 2020-2022 model year
Maverick FHEV 2022-2025 model year
Mondeo EVOS (China) FHEV 2022-2025 (2021 model year)
Lincoln Corsair FHEV/PHEV 2023-2025 model year
Lincoln Nautilus (CDX707) FHEV 2024-2025 model year
Lincoln Zephyr FHEV 2022 model year+ Service function PCM “EGR Valve Cleaning” for:
Galaxy 2.0 TDCi 2015/2020 model years
Mondeo Mk5 2.0 TDCi 2015 model year+ - Service functions PCM “Reset SCR inducement fault”, “Reset the oil change indicator” for:
Everest 2.2 TDCi 2015 model year
Ranger 2.2 TDCi 2015 model year+ Service function ABS/ESP “Calibrate Pressure Sensor” for:
B-Max (EU) 2012 model year
Ecosport 2012-2013 model years
Fiesta (EU) 2013 model year
Transit Mk7 (EU) 2006-2013 (2006 model year)+ - Service functions ABS/ESP “Apply and Release Calibration (Assembly Test)”, “Enter Electric Parking Brake Maintenance Mode”, “Exit Electric Parking Brake Maintenance Mode”, “Apply Electrical Parking Brake”, “Release Electrical Parking Brake”, “Apply left EPB actuator”,“Release left EPB actuator”, “Apply right EPB actuator”, “Release right EPB actuator” for:
Transit (Europe) with EPB 2019-2023 (2019 model year)
Transit (North America) with EPB 2020-2024 model years+ - Service functions ABS/ESP Calibrate Lateral Acceleration Sensor", “Calibrate Yaw Rate Sensor” for:
Fiesta (EU) 2008 model year+ - Service function ABS/ESP “Calibrate Longitudinal Acceleration Sensor” for:
Mustang (S550) 2021-2023 model years+ - Service functions ABS/ESP “Hydraulic Control Unit Inlet Valve Calibration”, “Hydraulic Control Unit Isolation Valve Calibration” for:
Mustang (S550) 2021-2023 model years+ - Service function ABS “ABS Service Bleed” for:
F-150 2007-2008 model years
Lincoln Mark LT 2007-2008 model years+ - Service function CCM “Calibrate Cruise Control Sensors” for:
Mondeo EVOS (China) 2022-2025 (2021 model year)+ - Service functions DDM “Power Window Initialization (driver’s side)”, PDM “Power Window Initialization (passenger’s side)” for:
Edge (CDX706) 2023+ model year
Lincoln Nautilus (CDX707) 2024+ model year+ - Service procedures IPMA “Local Interconnect Network New Module Calibration”, “Rear Camera Calibration”, “Pro Trailer Backup Assist Camera Calibration”, “360 degree View Camera Calibration” for:
Expedition 2022-2024 model years
Lincoln Navigator 2022-2024 model years+ - Service function IPMA “Lane Departure Warning System Camera calibration” for:
Expedition 2020-2024 model years
Maverik 2025 model year
Lincoln Navigator 2020-2024 model years+ - Service function “OCS System Reset” for:
Crown Victoria 2000-2011 model years
Escape HEV 2005-2007 model years
Expedition 2003-2006 model years
Explorer 2002-2005 model years
Explorer Sport 2003-2004 model years
Explorer SportTrac 2003-2005 model years
F-150 2004-2008 model years
Focus Mk1 2005-2007 model years
Freestar 2004-2007 model years
Mustang 2005-2009 model years
Taurus 2004-2007 model years
Windstar 2000-2003 model years
Lincoln Aviator 2004-2005 model years
Lincoln LS 2003-2006 model years
Lincoln Mark LT 2006-2008 model years
Lincoln Navigator 2003-2006 model years
Lincoln TownCar 2000-2011 model years
Mercury Grand Marquis 2000-2011 model years
Mercury Marauder 2003-2004 model years
Mercury Mariner HEV 2005-2007 model years
Mercury Monterey 2004-2007 model years
Mercury Mountaineer 2002-2005 model years
Mercury Sable 2004-2005 model years+ - Service function RCM “Crash Flag Reset” for:
Transit Courier (B460) 2014 model year
- added distributed PATS scheme to the information dialog in some PATS Programming functions
Improved/changed feature
- Improvements to “PATS Programming” function for new cars: proper handling “anti-theft lockout” and other states/issues in case of BCM replacement
- fixes and improvement in CAN communication procedure for STN chips
Bug fixed/removed feature
- service function PCM “Misfire Monitor Neutral Profile Correction” for Focus Mk3.5 1.6 Duratec StgVI 2015 model year (function was added in v2.3.66 but isn’t supported by this PCM)
- bug: unable to perform PATS Programming->Module initialization on some Mondeo Mk4 2011MY
- bug: unable to start DPF static regen on some new EU models
- bug: unable to enter ABS Maintenance Mode in some cases
- bug: unable to read IPMA Module Configuration (As Built format) on some Mondeo EVOS because of a bug in the IPMA module
