What do these errors mean?
Those are all communication errors on the CANBUS. It does happen from time to time. Clear the DTC errors and check later after the car is driven to see if they return.
DTC=Diagnostic Trouble Codes. There is an explanation of this in the FORScan user manual on the FORScan site.
Try being a bit more friendly with your question, some context, a clear picture etc…
Will do…sorry…i got nervous when i saw that…after work ill take more pictures an do as chief said…
Yes if it persists then it’s an issue, if you clear it and it doesn’t return nothing to worry about
