2018 focus 1.5t
Ask for a forscan backup file
PDM AND DDM
Thanks
If you have the VIN you can pull the ASBuilt file from Ford https://www.motorcraftservice.com/Asbuilt/
Or in ForScan while in the module you can select download factory.
The ddm and pdm in ASBuilt are incomplete when the forscan is flashed
If you are using a higher level of firmware than the car came with you will have unfilled blocks, this is perfectly normal.
As an example you’ll get the same thing when you drop the AB for say a 2018 APIM into a 2020 APIM.
You’ll also get this if you are using modules other than what came with the car, eg JU5T door modules when the car came with GR2 series modules.
