Help Identifying APIM
I recently purchased a SYNC 3 system from a crashed 2021 Mustang Eco Premium. The seller says is a non nav, but then said yes it is, the system is due to be delivered tomorrow, is there a way to tell if it is or not? I have tried searches but some say it is some say is not, so not sure if I need to get the GPS antenna for it. Here is the part number gr26a lr3t 14g370 bbm. Ford owners.com says there is a map update for it, using the donor car’s VIN. Any help would be appreciated.
Old SYNC Version: 3.4.20136
New SYNC Version: 3.4.20282
Don’t have the unit yet.
Once you have it operational, run the interrogator log against it or check the APIM’s model in the bezel diagnostics menues.
OK thanks!
No matter what you’ll need to get a GPS antenna for it or you’ll have DTCs showing for an open antenna circuit.
If you have the VIN go to https://www.motorcraftservice.com/Asbuilt/ and look at 7D0-01-02 x_xx xxxx xxxx a 0 in position number 2 is no-NAV, a 2 there is NAV.
Thanks for that info, I will check it, by any chance do you know if a 2020 Mustang Eco base model will have the antenna already?
OKI, then so according to this is a no nav here is a snip of that location.Hope is the correct one. Thanks again.
(attachments)
21 Ecoboost Premium did not come with Nav and it was not an option. Even the 201A package did not add it.
You dont get Nav until the GT 301A package.
Thanks for that info, good to know, I have a base 2020 but I’ll be using Google Maps, will try Waze to see if I like it, not sure why they told me it had it after telling me no. But I verified by looking at the code for that specific Vin number and it has a 0 and not a 2 so according to that table it has no nav, so I should not need a GPS antenna I hope.
If the car has Sync3 (8" screen) from the factory it has a GPS receiver already.
Depending on model/year some are part of the whip/shark fin base or an actual hockey puck style assembly mounted somewhere in the front of the cabin (eg in the dash above the cluster).
Hello, UPS is supposed to deliver the package today, once installed I will run the interrogator to get the details of that unit, that info will come handy later on.
Is this a 4" upgrade than?
Yes, from a crashed 2021 Mustang Ecoboost, convertible, Premium.
Hello, so I installed the radio display , receiver and the bezel, everything went great, the only issue is the climate controls, they are ghosted, the only icon active is the AUTO, but I tap on it and does nothing, the Hazard toggle need to be fix it requires the double action for on and off, the steering toggle does nothing, the drive mode does nothing. I know I’ll have to activate some of these functions, such as the drive mode, with forscan, but the climate control should be working and is not. I double checked the connections to the bezel and put the old base model bezel back on and everything worked as it should, so not sure if the bezel has an issue, the system has a 90 day warranty, hopefully I can get it to work. I know this is off topic. The unit does not have navigation.
so it’s a retrofit not a oem-replacement, please provide accurate information when creating your topic.
Tags updated
