Help updating BCM firmware.... 2019 F150
This is my first post on this site, I just discovered it, it seems like this is the spot to get the help i need.
I recently have done a bunch of mods to my 2019 f150 XLT. One of the mods was replacing the BCM. I have (2) replacement BCM’s. I have a 2018 limited from a donor truck i pulled parts from that came with a key programmed, and a 2019 platinum BCM i bought because i thought it would be better to use a module from my trucks exact year to eliminate any issues that might arise from using a truck of a different year. Before I got the PATS reset I hooked up the 2019 BCM. When i hit the start button I was not getting the “required no key detected” error for a PATS reset. I then tried the 18 BCM and I was also not getting the no key error. But when I hit the start button i noticed the shifter lock would release and i could move the shifter into different gears, this did not happen with the 19 BCM. The lack of no key detected error turned out to not be related to the BCM. So i figured out the issue and then got the no key detected error with both.
Yesterday I had the mobile locksmith come out. I had the 19 BCM hooked up, and he tried to preform a PATS reset, but he could not get it to work because there was no way to get the truck in ignition mode, I did not have a programed key for that BCM and the truck would not stay “Awake” long enough to complete the procedure. My next step was to install the 18 BCM, I did have a single programmed key for that, which allowed the truck to enter ignition mode with the key, and he was able to complete the PATS procedure. I now have 2 programed keys and the truck will start.
The problem Im having is that whenever i press the start button, foot off of the brake pedal the truck starts. I cant enter ignition on engine off mode for forscan programming. And bc of all the mods I have installed all at once, I have a ton of programming to do. I do not believe it is a brake position switch problem, the light on the start button does not turn green unless i actually press the brake, and the oscilloscope in PID in forscan shows no activity when the brake is not pressed. I believe this is an issue that has to do with whatever was going on before the pats reset when i hit the start button and the shifter would unlock. I cant find anything in am as built compare tool that would cause this between the two modules. I believe this might be a firmware difference in start logic between 18 and 19. Is there a way for me to load 2019 firmware on my 2018 BCM?
Thanks
High risk of the BCM becoming a brick…look at the park lock control and PASE setting in the BCM.
Why was it necessary to replace the original BCM? If you put the original BCM in the truck and perform a PATS reset, does it work normally?
There is little benefit to be gained by replacing the XLT BCM with that of a higher model unless you are rewiring the vehicle and adding features, of which there would be few. Most of the BCM versions are the same physically, and just updating the firmware and adding the appropriate wiring would work for the most part.
I replaced it because i have done a ton of mods and replaced out all cab wiring and modules with platinum/limited tier. I think the xlt bcm can handle most of them, but i also replaced the keyed ignition out with a push button/ intelligent access. That is what i needed the higher tier for, or at least what i thought i needed it for. Im new to the ford modding game, so i didnt realize firmware could be updated/changed on modules until is started looking into the no brake start issue
Understand. So a little more than just tinkering. But does the OEM BCM still work in the trucl?
I havent tried it… but im guessing not, the keys are a different style and the original RTM is a different frequency then the one i had to put in for the push button start. Ive also done a PATS reset with the replacement BCM, so i think even if there was a way to make it work with the original BCM i would have to call a locksmith out and pay for another PATS reset because it requires NASTF credentials to complete and the car can only be tied to one bcm at a time
