How do i enable autolock on IPC?
Hi, I have enabled autolock in BCM and autolock is working. I also wanted to activate the autolock menu in the IPC screen, but there is no autolock option when I check with Forscan in easy mode and not asbuilt configuration. Is there no way to enable this? The car is a Ford Focus MK3 2015.
Auto Lock on 2016 model - Ford Focus Club - Ford Owners Club - Ford Forums
