How to get calibration files for the 2024 Ford Puma ST-Line
About the only ones you can’t get with ForScan and the ones for the B&O DSP.
Thanks. I’ve already visited this website, but I didn’t find anything. The calibration files are for Forscan
The calibration files are for the vehicle.
Ford Puma St-Line X from 2024
Yes so you said above.
I thought you were asking what car it is, yes, they are for the car
Get FORScan and a USB OBD adapter. (Don’t use BT for updating firmware, you may regret it.)
You need the paid licensed version of Forscan to update firmware files and obtain support thru FORScan.
Read the instructions and understand the firmware update process before you do anything.
Obtain the factory asbuilt for your vehicle BEFORE you do anything with FORScan on your vehicle.
https://www.motorcraftservice.com/SetCountry?returnUrl=%2FHome%2FIndex
Load FORScan, connect to the vehicle, capture a profile first. Save this profile.
NOTE: Any time and each time you update the firmware for ANY module on the vehicle you need to save a new profile for the vehicle in FORScan.
Connected to the vehicle thru the OBD adapter, open each module to program the firmware and check them one at a time for new files. Download the original files first and then download the new files. This provides you with a backup of the module firmware in case you need to return to it because of a failed update.
Once you have the files downloaded, you can go thru and update the modules as needed following the instructions posted by FORScan.
