Hello! maybe somebody have researched this question? I need the language pack french and the maps of thailand. As I understand it, there is only one country code.
You can use the Syn3 Updater to do this.
You need ROW maps: 4U5T-14G421-FAH 4.9Gb Sync3 v3.2.20147
and a language file that contains French: 5U5T-14G391-FP 1.4Gb Sync3 v3.2.20339
The app file will be the latest Sync, 5U5T-14G381-ES 847Mb Sync3 v3.4.21098 09.04.2021
Thank You for your answer. I have updated files with Syn3 Updater. And now I have interface and voice on my native languge. It is perfect
But Maps are not working. Just a black screen.
This is maps files which I upload.Maybe You know how to fix it?
Have you performed a master reset?
Also, what was the original region for the car/unit?
Yes, after updating the files, I did a general reset. Vehicle purchased from a Ford dealer in Thailand.
so you have changed this?
Yes, I have changed it with Forscan and OBD scaner. Only after that I saw my languge in settings
Run the APIM Interrogator Tool and post the results. Also post the log file from the Syn3 Updater, please.
Sorry, but I have only log of second (last) updates- updates of map.
Assuming you have used the latest version of Syn3 Updater you will have all logs.
thank you very much. I have found my first log too.
Your country code shows RS for Thailand which does not seem to be a valid code. (5253) Try TH for Thailand (5448).
If I set the country code to Thailand, then my native language and voice are not there and I can only set Thai and English.
The country code needs to be set for your location for the maps to function properly. In your case, Thailand. But I understand your native language is French, which is not a choice when your country code is set to Thailand. I think this is a case where the settings in Sync will not accommodate what you want to do.
And in this case there is no any solution? I can’t use maps and keep my native language at the same time?
