I installed a JL3T-14G087-CK 4G modem in my 2017 Continental. Modem is working and has a strong signal.
I cannot advance off of the Waiting for Auth Mode
In the Auth-State PID
Any help would be appreciated.
What did you use for the config of the TCU?
Did you leave it at what it came with from the donor or did you drop your’s in?
Did you update the calibration of the TCU to -CM?
Have you performed a master reset of the APIM?
Have you logged out of the FordPass app entirely?
The only change I made to the TCU was B100 to the top line.
The calibration level is FA1T-14G087-DM
I didn’t see that there was an update.
The strategy is FA1T-14G139-AT
I’ve performed reset on TCU,APIM, i DOD A Master reset on the system and also reinstalled the Lincoln app.
Thank You for you’re help
I’m just smart enough to get me in trouble
Awesome. Thank you I will give that a try.
Thank you for your help.
Much appreciated.
Working great.
