In my Ford Fusion i changed IPC to Mondeo mkz. After change i had some isseus
Hi everyone, i have ford fusion 2017 model with sync 1. i changed my sync1 to sync3 use update kit (only AIPM). it works very well. Then i bought new key with 5 buttons for remote start. After adding new key, remote start does work very well. (my original key with 4 buttons and remote start does not works with this key).
Now i bought new cluster (mkz mondeo speedometer). I was setup this speedometer to my ford. I works good. But i have smoe issues.
  1. Remote start does not works now (After change cluster to mkz mondeo).
  2. Forscan show error with Code: U0100 - Lost Communication With ECM/PCM A
  3. Cluster dont show gear shifts on the screen (P, R, N, D, S).
I found new version for the mkz cluster and was updated with forscan. i got new functions on mkz mondeo cluster.
But this 3 issues were not fixed.
Anybody cant help with this issues?
Check on the ForScan fourms, you might also find info on 2gfusions as there are a few threads about doing the MKZ IPC conversion.
2gfusions.net, use http for the url, don’t know why its getting truncated on here
Thnx for your reply. but i cant find anything about this in 2gfusions.net forum.
http://www.2gfusions.net/printthread.php?tid=5855&page=1
And there’s threads on reddit and elsewhere.
thnk u for your reply. i was found information about this. i was ordered eeprom reader. after getting i will change parameter for eeprom and write here about result.
thk u for your help :v:t2:
