Hi All! I just recently did a single FOREscan change listed below. I did the common update to turn off the doo-doo-doo chime upon ignition start. This is the ONLY change I have made using FOREscan. It did correctly disable the ignition start chime, however, now ALL of my other alerts (blinker sound, backup alarm, rear cross-traffic alarm, door ajar chime, etc…) are only coming throught IPC and no longer the speakers.
Might help if you show us the config before and the config after.
The ForScan easy buttons aren’t always correct.
I’m sorry! I thought I included that in the original post but I guess I didn’t.
Original IPC FOREscan values: 720-01-02-221F-90FB
Updated IPC FOREscan values: 720-01-02-221F-92FB
