IPC Navigation Turn by Turn
Hi I am trying to activate this feature in my IPC. Can someone please help me with this
Currently I only have compass like this
I tried activating it in the simple ForScan configuration - Turn by turn navigation
But this doesnt work, I can only see the compass.
Credits to the pictures above.
Here is my current IPC AS Built
I belive this only works when you have a destination entered into the Nav. Assuming you tried that? You need to turn on the Nav repeater in the APIM.
Thanks for this one. What’s the correct value? Currently the value set for my car is 0
To answer your question as well, yes I tried entering the destination in the Nav app, turn by turn doesnt show in my IPC
Try 2 or 4. I dont know your options so I can only guess.
Thanks. Will try it
Keep in mind this only works with factory NAV, Google Maps and Apple Maps (if I remember correctly on this one).
It doesn’t work with Waze, Sygic, Here, etc
The APIM must have OEM nav and have the option enabled in the APIM for the proper region, like Telenav, etc. This sends the messages for the nav repeater function to the IPC. Google and Apple work after that. The others don’t seem to support it, apparently. Or if they do I have not seen an example.
Thanks for the info. Yes I have an APIM with Nav. What are the codes to check for this function to properly work?
Did the last 2 options I gave you not work?
Yeah not sure if I activate it. I tried the Sync Nav app it doesnt show the turn by turn but I am inside a parking building and the system is searching GPS.
As for Apple Maps the IPC shows Check Touchscreen and when I check the screen it takes me to Carplay and the maps says turn by turn for this destination is not available. Not sure if this just a Apple Map setting issue.
I havent tried Google Maps in Android Auto. I will do this tomorrow I will borrow my friends Android phone
Thanks for your input on this I manage to test it using Android Auto using Google Maps screenshot attached.
I will check my Apple Maps setting hoping to activate the turn by turn in Carplay. Turn by turn is showing in iPhone not sure why it wont show in Carplay.
Good to hear, What setting did you use?
Hi. I use #2 in NAVRC. Next for me now is how to fix my Apple Maps in Carplay. Thanks again
I just found that turn by turn navigation of Apple Maps is not supported by Apple in my country :smiling_face_with_tear:
Hi. One more thing. I have this APIM DTC that I am unable to clear - GPS Antenna: Circuit Open.
Sometimes the Navigation Fault pops in my screen but if I drive in open spaces the navigation goes to normal. I can see there’s a GPS signal, satellite are also visible in the APIM diagnostic/testing menu.
My question is will it harm the APIM if I just ignore it or this should be addressed by replacing the GPS antenna? I am using Google maps for navigation which I think uses my phone’s GPS
It won’t “hurt” the APIM.
The fault means you either have a bad connector, cable or bad GPS receiver.
It wont harm the APIM. This is a common DTC when you do a Sync 3 retrofit and use an aftermarket antenna that does not ground out. Many of us have found factory antenna’s and retrofitted those for better results.
