IPC replacement
Hi everyone, I need to replace
the IPC module: 8V4T-10849-GJ
with 8V4T-10849-GF.
I'm using Forscan v 2.4 Beta with
the Vlinker OBD extended license.
My question: after installing it,
I just need to copy the AB of the old
IPC. Obviously, I'll find the mileage
of the donor, hoping it's
less than my 225,000.
Is everything I said correct,
or am I missing something?
Thanks everyone, any advice
is welcome.
Hopefully you set the mileage correctly…more information would be required to give any advice, like why you are going backwards for the IPC. Copying the asbuilt should work, but you will need to compare the files first.
everything went well thanks
