IPMA gives configuration error
Hello, in my fiesta mk8 I have IPMA as following:
IPMA - Image Processing Module A
Part number: H1BT-19H406-BG
Calibration level: H1BT-19H406-BG (latest known: N1BT-19H406-BA)
Strategy : JX7T-14F397-AH
Calibration: H1BT-14F398-AG
By information found online it should -Bx model should support:
LDW, LKA, DAS, AHB, TSR, WWA
While almost all the features are enabled by factory, Wrong Way Assist is disabled and gives configuration error when I write to the module using forscan.
Is it too early hardware? Or should I try firmware update, since it is available?
Probably. Firmware update would be a good bet. IPMA is reported to be a little finicky, so take your time. You will need to run a calibration after the firmware update.
LOL… You also have to run a re-calibration if you drop in the factory AB or restore the config from ForScan.
lol what?
Since it failed to write the new configuration there are no changes made to the module
Some of the IPMAs are so temperamental that any attempt to change the config/firmware triggers off a missing calibration DTC.
That even includes backing up the current config with ForScan and putting it back in without any changes.
And that’s what you’re getting wrong, there is no missing calibration DTC. It’s a popup that forscan throws while writing to the module (around 50%, probably because here there’s the block for the wwa function). And by throwing this error it doesn’t write to the ipma any new or old data.
When I have some time to spare I will try to update the firmware, since it’s available and it seems like the only possible issue here
I didn’t say you had a DTC.
I said that some versions of the IPMA are so finicky that ANY attempt to change config or update the calibration/firmware will throw a missing calibration DTC.
That would include a failed attempt.
ForScan 2.4.x now has an option drop down to kill all communication on the bus from other modules, you may need to change that.
Updated the IPMA module, update successfull.
Now I got DTC for U2100. Noticed that there is a problem with as built…
706-04-01 is now set at 0000-03C3-4018
my saved values are FFFC-27C3-4037
Writing to the module ok but the error keeps popping up, when I reload AB from the module it reverts to 0000-03C3-4018
u2100-00 initial configuration not complete
You need to run the module calibration procedure, it can be done with ForScan.
You’ll need a road that’s decently straight with well marked lines that you can drive on at a set speed of 50-60mph for a mile.
While the existing config and calibration is saved using ForScan you can’t write the calibration back.
Calibration has already been executed. There was a separate DTC related to the calibration not been done. Now it’s just this error
If the calibration was performed and you still get the DTC back after clearing it and a module reboot the calibration wasn’t accepted by the module.
I ran the procedure twice… I’ll try again.
Just one thing maybe I didn’t understand:
when the bar reaches 100% it doesn’t end the procedure or pop up anything… is this the normal behaviour?
I guess it is normal since it says
It’s just like flashing a calibration/firmware to a module.
There’s no splash that says it completed.
So the calibration was completed…
I tried to:
-do calibration camera (in this order: load factory ab - calibrate - reboot module)
-do calibration camera (in this order: load saved ab - calibrate - reboot module)
-upload as built saved before
-upload as built from ford servers
Note to self: Do not update modules with FORScan.
Luckily, I had one-day access to FDRS and used it to run the Programmable Module Installation for the IPMA—problem solved in 30 seconds.
Side note: I noticed a lot of the updates shown in FORScan aren’t actually available in FDRS. I just installed the ones that were in fdrs, and called it a day.
With IDS and FDRS you’ll also see that some updates have other module pre-reqs that ForScan doesn’t show.
ForScan isn’t perfect for flashing every module on every model by a long shot.
This wasn’t my case, but I noticed for example, since I retrofitted front pdc forscan correctly reads the new PAM since it scans the can netwotk while fdrs from my understaning reads only this data from the vin since it still show the old PAM (the model that manages only rear pdc)
Correct.
Also if you do a mod and add something to your car that your model never had ForScan won’t find the module either on a normal scan.
You have to use a saved scan from a model that had the module in order to config the module.
