I have a 2015 Ford F-150 and I need to change the camera controller parameter from LIN to CAN inside the BCM (as built with Forscan). or from BCM to IPMB to remove speed limit in back camera now i already changed bcm to ipmb but nothing happend it just turned the screen black
The speed limiter is in the APIM for the camera’s. You can’t disable it with Forscan.
This is done the jailbreaking the APIM. That is the only way unless you can spoof the speed signals to the APIM. The jailbreak mod is not using the VSS.
