Lincoln navigator screen
Does a 10 inch screen out of a Licoln navigator sync 3 work with any sync 3 apim , as it shares the same connection as the 8 inch ?
Install Type: OEM Replacement
Old SYNC Version: 3.0.25306
New SYNC Version: 3.4.20220
Yes, but I believe you will have to change the asbuilt value for the larger screen.
Thanks for the reply . I did assume that but didnt know if all of the sync 3 units had the option in the firmware to cater for that display as want one for a project in the u.k. and wasnt sure there would be anything in a ford focus sync 3 apim for a 10 inch screen .
Do you know what you would have to change and what to change it to ?
Do not double post / bump the thread, use the edit button instead.
Check both:
My apologies. Wasn’t my intention to bump the thread or whatever that means .
Youve put solved but apart from state rules you havent helped me at all.
It’s solved because that’s the solution, if you do not know how to use Forscan and change 2 simple values that does not mean that’s not the solution. Besides, your original question was if you could use a 10 inch screen, so yes, the solution is that yes you can.
Google / research about that and even you will be able to do so, you will need Forscan and an adapter if it comes to that.
Or, pay someone else to do it.
Ive used forscan and ids plenty of times thanks and remap vehicles .
Ive looked in all of tne asbuilt values and cannot see anything relating to tbe screen size like you get with sync 4 which you can actually set it to the size and between horizontal ane vertical.
Is sync 3 pogrammed so that its already in the firmware for the 10 inch screen or is there a line in the asbuilt data for it .?
Uh?, just an example:
DE02/7D0-03-01: xxxx-**xx-xxxx
07=Lincoln 10L MY20 (10" Landscape) (Lincoln 10L MY20 10" Landscape theme with custom Boot Screen)
08=Ford 10P MY20 (10" Portrait) (Ford 10P MY20 10" Portrait theme with custom Boot Screen)
How is that not related to size?
Thank you very much . I just couldn’t find it thats why i asked the question. I had looked but just couldn’t find that. It was not through not looking .
What vehicle did they have a 10 inch portrait screen in with sync 3 ?
About that, I would not know.
No model comes to mind, but I’ve seen pictures of the iconic “Tesla screen” around.
