Looking for EEPROM file
TLDR - I need a VBF format L1TT 10849 eeprom file please if anyone can share.
Happy to pay if required but avoiding scammers.
I have a Ford Transit 2018 that I retrofitted with a Puma 2020+ IPC. Part Number is N1BT 10849
Custom FW was loaded onto it, but it was L1TT 10849 calibration so the eeprom file was loaded to match. When loading the eeprom on forscan it came up as ‘Kuga’ but as I wasn’t flashing it I didn’t pay too much attention.
Now my backlight dim buttons won’t work on the IPC. They work for sync screen etc but IPC remains 100% brightness and is a killer at night.
A friend who has same FW on another IPC but P/N L1TT has dim buttons working absolutely fine. When he bought a younger van with less mileage he used same eeprom to lower mileage and now has same issue with dim buttons so assuming the eeprom is wrong. Looking for an eeprom in VBF format so I can use forscan to flash.
TIA
