MS1 CAN+ ,MS1 CAN - vs HS1 + ,HS1 -?
Hey everyone, I’m currently in the process of installing electric OEM running boards on my 2015 XLT. I recently obtained a set of OEM electric running boards from a 2023 F250. I have a “PRB” module from a 2015 F150 Platinum and the motors and brackets from a 2015 F150. I’ve already completed all the wiring, but I need to connect to power. My plan is to tap into the fuse for the moonroof since I don’t have one. I also need to connect to “MS1 CAN+” and “CAN-” and I’m considering tapping into the wiring harness from the rear right pillar. In the diagram, it indicates that the cables are grey-orange and violet-orange. I’ve located the wires already, but there are two pairs of twisted wires with the same color. How can I verify which wires are the ones I need, given that there are two pairs of twisted wires with the same description?
Also, I ran the wires from c2122 to be used with my retrofit TCU, which uses HS3 CAN + and HS3 CAN -. Can I use the wire from port c2122, cable 3 and 4 , which is medium speed CAN + and -? uploading pictures for refrences
Odds are both those pairs are the same canbus.
are you talking about the data connector c2122 behind the obd connector? or the pillar cables from the rear?
Pillar wires.
I want to confirm if I can use the high-speed CAN bus wires from the pillar even though the RBM requires medium speed. Or should I use the wires from C2122 cable 3 and 4, which are medium speed CAN+ and CAN-? What do you recommend?
No you have to use the correct canbus for it.
