NA 2025 (Released 2026) Maps add to Syn3 Updater
2025 (2.25) Maps for NA have been found online and added to Syn3 Updater! thanks once again to @AuRoN
This release only updates the Nav, Voice Nav package no new application etc.
It IS ESN locked as per other NA map packs
Rules
  • Do not reply to this thread with general issues that are not specific to 2.25 Maps
  • If you notice a bug or change specific to this feature report it below
Failure to follow the above rules will result in your post either being moved (if moderators or myself are feeling generous) or deleted without prompt
To clarify, MEM_ERR’s, Missing Logos, LST_ERRS etc should not be posted here, make a new thread using this Support Link
Install Methods
Syn3 Updater
Manual Method
It’s also added to the manual method available at the below link
Cutdown Maps
It’s also added to the cut down maps at the below link
Package URLs
Nav Voices:
4U5T-14G422-CAR
4U5T-14G422-CBR
4U5T-14G422-CCR
Maps:
4U5T-14G421-CAJ
4U5T-14G421-CBJ
4U5T-14G421-CCJ
4U5T-14G421-CDJ
4U5T-14G421-CEJ
4U5T-14G421-CFJ
4U5T-14G421-CGJ
4U5T-14G421-CHJ
4U5T-14G421-CJJ
License:
4U5T-14G424-CJ (ESN Locked)
SYNC 3 Common Issues and FAQ’s
Technical Information from FMods
— New 2025 US Maps Released —
Release date: 28 Mar 2026
Packages Date: 19 Mar 2026
Maps Date: ??? 2025
Did the update with full master reset and dropped my APIM AB back to factory, ran into late voices in the Indianapolis area.
