Need help aquiring "As Build" file for APIM (have vin)
Hello, i installed APIM from a Kuga 2 to get 3.4 and AA/ACP in my Mondeo, most things function, but i need a “As Build” file to make the most of the new APIM.
I have forscan, and can connet to the car etc, i also found a similar car, with the needed accessoires, and have the win, but i cant find a place to aquire the “As Build”. where to go? or can anybody help?
Regards
Peter.
Old SYNC Version: 3.0.19205
New SYNC Version: 3.0.19205
no
Get the VIN from a car with the first Mondeo Sync3 year (here in the states on the Fusion that was 2017) and use it to pull the AB from https://www.motorcraftservice.com/Asbuilt/
Just a follow up, got the as build file, which helped, but then i had parking aid problems, since the donor as build was a wagon, and mine is not, so i got the as build file from my own vin, and used it on parking aid module, now everything is working as i want. Thanks for the help.
