Hello, I am trying to find the communication port that the GPS works on, so I can use it with apps inside of Total Commander. I have looked inside the GPS shockwave file that powers the navigation system, nothing, and it doesn’t help. I found two GPS dll files looking inside the windows folder on the system, and I cannot do anything with them as I cannot copy them to a SD Card or USB drive to attempt to see what they do.
As for the navigation software, when using a program called 7Ways, it asks for a port and baud rate, which I cannot find. Many other apps also ask for this as well. I have tried to find it, and it seems to find the correct COM port (being labeled as ‘COM1:’ inside the settings file) but i cannot find the baud rate. I am currently at a loss on how to proceed and connect. I can provide any settings or configurations I have, but nothing involving an OBD port (as my reader is a cheap knockoff and wouldn’t be able to get much data)
You can get this info with a subscription to Oasis. It will show you the data paths and networks the GPS data travels on. Once you know the network it also tells you the speeds of those networks.
What’s Oasis? I’ve never heard of it much, if at all.
Here is a link, I recommend a 72 hour subscription unless you filthy rich.
Thanks, I might see if this will help with what I’m looking for. Anything else that could help in case this doesn’t?
