I did a rear camera recalibration with Forscan, and now I see a bunch of DTC codes. I would greatly appreciate it if anyone could point me in the right direction clearing these DTC codes.
2015 Ford Mustang V6, upgraded from sync 4 inch screen to 8 inch screen, running navigation and sync 3.4 version.
Old SYNC Version: 3.4
===PCM DTC None===
Successful DTC reading, no error codes found
Module: Powertrain Control Module
===END PCM DTC None===
===OBDII DTC None===
Module: On Board Diagnostic II
===END OBDII DTC None===
===APIM DTC U0151:00-08===
Code: U0151 - Lost Communication With Restraints Control Module
Status (-08):
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
===END APIM DTC U0151:00-08===
===APIM DTC U0155:00-08===
Code: U0155 - Lost Communication With Instrument Panel Cluster (IPC) Control Module
Status (-08):
===END APIM DTC U0155:00-08===
===APIM DTC U0159:00-0A===
Code: U0159 - Lost Communication With Parking Assist Control Module A
Status (-0A):
- DTC Present at Time of Request
===END APIM DTC U0159:00-0A===
===APIM DTC U0184:00-0B===
Code: U0184 - Lost Communication With Radio
Status (-0B):
===END APIM DTC U0184:00-0B===
===APIM DTC U0198:00-48===
Code: U0198 - Lost Communication With Telematic Control Module ‘A’
Status (-48):
- Test not complete
===END APIM DTC U0198:00-48===
===APIM DTC U0238:00-0B===
Code: U0238 - Lost Communication With Digital Audio Control Module D
Status (-0B):
===END APIM DTC U0238:00-0B===
===APIM DTC U0293:00-48===
Code: U0293 - Lost Communication With Hybrid/EV Powertrain Control Module ‘A’
Status (-48):
- Test not complete
===END APIM DTC U0293:00-48===
===APIM DTC U0452:00-08===
Code: U0452 - Invalid Data Received From Restraints Control Module
Status (-08):
===END APIM DTC U0452:00-08===
===APIM DTC U2101:00-0B===
Code: U2101 - Control Module Configuration Incompatible
Status (-0B):
===END APIM DTC U2101:00-0B===
===BdyCM DTC B1D35:11-0A===
Code: B1D35 - Hazard Switch
Additional Fault Symptom (:11):
- Circuit Short To Ground
Status (-0A):
Module: Body Control Module
===END BdyCM DTC B1D35:11-0A===
===BdyCM DTC B1147:15-48===
Code: B1147 - Left Front Fog Lamps
Additional Fault Symptom (:15):
- Circuit Short To Battery Or Open
Status (-48):
- Test not complete
===END BdyCM DTC B1147:15-48===
===BdyCM DTC B1148:15-48===
Code: B1148 - Right Front Fog Lamps
Status (-48):
- Test not complete
===END BdyCM DTC B1148:15-48===
===BdyCM DTC B115E:55-08===
Code: B115E - Camera Module
Additional Fault Symptom (:55):
- Not Configured
Status (-08):
===END BdyCM DTC B115E:55-08===
===BCMB DTC U0207:87-08===
Code: U0207 - Lost Communication With Moveable Roof Control Module ‘A’
Additional Fault Symptom (:87):
- Missing Message
Status (-08):
Module: Body Control Module B
===END BCMB DTC U0207:87-08===
===MRCMB DTC None===
Module: Movable Roof Control Module B
===END MRCMB DTC None===
===FCIM DTC B1A64:15-0A===
Code: B1A64 - Left Solar Sensor
Status (-0A):
Module: Front Controls Interface Module
===END FCIM DTC B1A64:15-0A===
===FCIM DTC B1A63:15-0A===
Code: B1A63 - Right Solar Sensor
Status (-0A):
===END FCIM DTC B1A63:15-0A===
===FCIM DTC U2024:51-08===
Code: U2024 - Control Module Cal-Config Data
Additional Fault Symptom (:51):
- Not Programmed
Status (-08):
===END FCIM DTC U2024:51-08===
===FCIM DTC B11E6:14-0A===
Code: B11E6 - Right HVAC Damper Position Sensor
Additional Fault Symptom (:14):
- Circuit Short To Ground Or Open
Status (-0A):
===END FCIM DTC B11E6:14-0A===
===MRCMA DTC None===
Module: Movable Roof Control Module A
===END MRCMA DTC None===
===OCS DTC None===
Module: Occupant Classification System Module
===END OCS DTC None===
===ABS DTC None===
Module: Antilock braking system
===END ABS DTC None===
===RTM DTC None===
Module: Radio Transceiver Module
===END RTM DTC None===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===PSCM DTC U0415:00-48===
Code: U0415 - Invalid Data Received from Anti-Lock Brake System (ABS) Control Module ‘A’
Status (-48):
- Test not complete
Module: Power Steering Control Module
Freeze Frame #1:
-STEER_FEEL: Normal - Steering Personalization Status
-STRWHL_POS_CAL: No - Steering Wheel Position Sensor Calibration
-SW_RAW: -0.10 ° - Steering Wheel Angle - Raw
-SW_ANGLE: -1.80 ° - Steering Wheel Angle
-SSHFT_TQ_S2: -0.5 Nm - Steering Shaft Torque Sensor #2
-SW_ALIGN_OFSET: 1.70 ° - Steering Wheel Angle Alignment Offset
-TOTAL_DISTANCE: 120734 km - Total Distance
-EVENT_TIME: 441238 s (Thu Nov 30 22:24:40 2023) - Event time
-ECU_POWER_SUPPLY: 13.6 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 16 °C - ECU Internal Temperature
-EPAS_MOTOR_CUR: 0.10 A - EPAS Motor Current
-VSS: 0.0 km/h - Vehicle Speed
===END PSCM DTC U0415:00-48===
===PSCM DTC U3003:16-08===
Code: U3003 - Battery Voltage
Additional Fault Symptom (:16):
- Circuit Voltage Below Threshold
Status (-08):
Freeze Frame #1:
-SW_RAW: 0.00 ° - Steering Wheel Angle - Raw
-SW_ANGLE: 0.00 ° - Steering Wheel Angle
-SSHFT_TQ_S2: -0.4 Nm - Steering Shaft Torque Sensor #2
-SW_ALIGN_OFSET: 2.50 ° - Steering Wheel Angle Alignment Offset
-TOTAL_DISTANCE: 120637 km - Total Distance
-EVENT_TIME: 441186 s (Thu Nov 30 22:23:48 2023) - Event time
-ECU_POWER_SUPPLY: 8.9 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 12 °C - ECU Internal Temperature
-EPAS_MOTOR_CUR: 0.00 A - EPAS Motor Current
===END PSCM DTC U3003:16-08===
===ACM DTC None===
Module: Audio Control Module
===END ACM DTC None===
===SCCM DTC None===
Module: Steering Column Control Module
===END SCCM DTC None===
===IPC DTC None===
Module: Instrument Panel Control Module
===END IPC DTC None===
===GWM DTC None===
Module: Gateway Module A
===END GWM DTC None===
===GPSM DTC None===
Module: Global Positioning System Module
===END GPSM DTC None===
