Hello everyone,
I wanted to replace the radio in my 2018 Focus with one that supports DAB+. The installed ACM module was the JX71-18K810-UBH. The new ACM module is the JX71-18C815-VU.
I followed the guide from My-Ford-Focus exactly. The saving of the configuration from the K810-UBH went without problems. However, when writing to the C815-VU, the error message “Configuration Structure Mismatch” appears.
The OBD2 adapter I used was the following one from Amazon:
bbfly Forscans Elm237 ELMconfig USB VINT-TT55502 MS-CAN.
After researching, I found that the APIM module might need to be configured differently. However, there was no further information on that.
Can you attach both of the as-builts you have for the ACM’s…Save them and attach them to your reply. You can just make the changes needed manuall one at a time on the new ACM also.
Here are the two configurations. Is there a website where I can download the original configurations? The new ACM module also doesn’t have the DAB tuner option.
Where can I get the original configuration for the C815-VU? The other one would only be for everything original in my vehicle. So far it doesn’t work at all with the acm module
