No bluetooth audio and Burton
Good evening, I recently purchased a 2018 Ford Fiesta 1.5, but I’m having a couple of issues with the Sync system (version 3.4), though the website shows version 3.02. The previous owner replaced the display, and now the buttons below it are not backlit. Additionally, even though the phone connects perfectly to Bluetooth, the audio does not come through the speakers. Has anyone had similar experiences or knows how to fix these issues? Thanks in advance for any advice!
Sounds like he swapped other things, either way if it’s OEM equipment then writing the default AsBuilt to the APIM and the FCIM should cure that.
Thanks for the info! Do you know if there’s a guide or some steps I can follow to solve the issue by writing the default AsBuilt to the APIM and FCIM?
Pop over to forscan.org and have a good read.
Here is the Ford AB link to get your OEM settings.
- FordServiceInfo.Com
