No Bluetooth on Sync 2.5
I’m hoping someone can help and possibly point me in the right direction. I’ve got a 2021 Ford Transit Custom with the 8 inch screen and sync 2.5. It’s supposed to have Bluetooth and system WiFi but these can’t be toggled on or off within the settings and the Bluetooth option is greyed out. From what I can gather using ForScan the configuration may not have been set up correctly to allow Bluetooth to function. Does anyone have the correct .vbf files or know of any reason why it wouldn’t work? I’ve tried every possible option and still had no luck so far. Or are there any options within the as-built file that will let me enable it.
VIN - WF0YXXTTGYMJ68870
ACM details are as follows -
Part Number: LK2T-18D804-HE
Calibration level: LK2T-18D804-HE
Strategy: L1BT-14F465-GC
Calibration: JX7T-14F466-HD
Download your default AsBuilt and restore that
https://www.motorcraftservice.com/AsBuilt
I tried this and it’s made no difference.
Not the issue. BT is active independent of firmware or software.
BT is not controlled thru the ACM, but through the APIM. Master reset the APIM and see if the issue still exists.
I don’t have an APIM, it’s sync 2.5 and everything is done through the ACM. It seems the Bluetooth and WiFi functions of mine are faulty so it’s a replacement ACM that’s needed.
