No gps after update to 3.4 interrogator file
nterrogator file
<p:OTAModuleSnapShot xmlns:d2p1=“urn:ford/Vehicle/Module/Information/v3.0” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:p=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0” version=“2025-02-22” xsi:schemaLocation=“urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd”>
<p:VIN>********************</p:VIN>
<p:RequestRole>
d2p1:RoleCONSUMER</d2p1:Role>
d2p1:RoleDescSYNCGEN3</d2p1:RoleDesc>
d2p1:RoleIDOTA</d2p1:RoleID>
</p:RequestRole>
<p:BroadcastDTCType>
<d2p1:DTC DTCValue=“96001108”/>
<d2p1:DTC DTCValue=“919f130b”/>
</p:BroadcastDTCType>
<d2p1:ECUAcronym name=“APIM”>
d2p1:State
d2p1:ResponseNU5T-14G381-AD</d2p1:Response>
</d2p1:DID>
d2p1:Response315535542d3134473432312d42414c000000000000000000315535542d3134473432312d42424c000000000000000000315535542d3134473432312d42434c000000000000000000315535542d3134473432312d42444c000000000000000000315535542d3134473432312d42454c000000000000000000315535542d3134473432312d42464c000000000000000000315535542d3134473432312d42474c000000000000000000315535542d3134473432312d42484c000000000000000000315535542d3134473432312d424a4c000000000000000000315535542d3134473635382d414800000000000000000000315535542d3134473432342d424e00000000000000000000345535542d3134473432322d42414c000000000000000000345535542d3134473432322d42424c000000000000000000345535542d3134473432322d42434c000000000000000000345535542d3134473432332d414300000000000000000000355535542d3134473339312d415400000000000000000000</d2p1:Response>
</d2p1:DID>
d2p1:Response345535542d3134473432322d42444c000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
d2p1:Responsee663ebf6</d2p1:Response>
</d2p1:DID>
d2p1:Responsed0103a29</d2p1:Response>
</d2p1:DID>
d2p1:Response8a6a05da50027c0440c2</d2p1:Response>
</d2p1:DID>
d2p1:Response554b0b0ac28a1c90a8b80e04</d2p1:Response>
</d2p1:DID>
d2p1:Response0000010000</d2p1:Response>
</d2p1:DID>
d2p1:Response00001d82310101</d2p1:Response>
</d2p1:DID>
d2p1:Response190819082653</d2p1:Response>
</d2p1:DID>
d2p1:Response80</d2p1:Response>
</d2p1:DID>
d2p1:Response0b0533000000006428000056565f0061</d2p1:Response>
</d2p1:DID>
d2p1:ResponseDS-1U5T-14G371-EL</d2p1:Response>
</d2p1:DID>
d2p1:ResponseGU5T-14G380-FF</d2p1:Response>
</d2p1:DID>
d2p1:ResponseNU5T-14G371-GAA</d2p1:Response>
</d2p1:DID>
d2p1:Response1U5T-14G375-HA</d2p1:Response>
</d2p1:DID>
d2p1:ResponseN17V00HL</d2p1:Response>
</d2p1:DID>
d2p1:ResponseBlank</d2p1:Response>
</d2p1:DID>
d2p1:Response03</d2p1:Response>
</d2p1:DID>
d2p1:Response1U5T-14G374-EL</d2p1:Response>
</d2p1:DID>
d2p1:Response</d2p1:Response>
</d2p1:DID>
d2p1:Response34:08:e1:cf:df:d7</d2p1:Response>
</d2p1:DID>
d2p1:Response34:08:e1:cf:df:d8</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime=“2025-02-22T17:13:28+00:00” RAM=“930529280” vmcuVersion=“Vector_VMCU_05.04.27”>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.2G” available=“976K”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.0G” available=“15M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.4G” available=“14M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.6G” available=“7.8M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.4G” available=“17M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.7G” available=“26M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“41M” available=“312K”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.4G” available=“4.9M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.4G” available=“27M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“4.9G” available=“29M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“5.0G” available=“30M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“4.5G” available=“26M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“3.8G” available=“37M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“1.9G” available=“8.4M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/grace” total=“1003M” available=“21M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/” total=“1.2G” available=“967M”/>
<d2p1:PartitionHealth type=“/fs/mp/resources” total=“72M” available=“332K”/>
<d2p1:PartitionHealth type=“/fs/images/” total=“54G” available=“9.5G”/>
d2p1:InstallationLog/
d2p1: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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
Old SYNC Version: 3.2
New SYNC Version: 3.423188
Gps symbol has red circle and strikethrough symbol. Nav does not work.
Have you done a master reset?
Hi
I’ve done master resets between map updates after the gps stopped working but I wasn’t aware or doing them until the gps stopped working in the update to 3.4
Sometimes when you do a software update to 3.4 the Nav ceases to operate unless you follow the upload in the car with a master reset.
You need to look for DTC’s concerning GPS and/or ABS maifunction. If they are present yu will need to correct those.
