No Maps available for selection in Manual Method
As I work my way through the manual method (Mac user) I am finding no options for selecting maps for any of the builds available. Based on comments I’ve been looking for 3.4.22110 w/ a map update from 2020. I’ve been trying to… re-load, delete browsing data, restart, reboot, nothing seems to bring back the map options for the manual method. I also saw this happen yesterday, but was able to finally see map options after clicking and changing the dropdowns. Based on yesterday I thought it was just a ‘touchy’ database, but now I’m not seeing any maps regardless of what i try.
Old SYNC Version: 3.0.20204
New SYNC Version: 3.0.23219
None
3.4.22110 is not an optimal build for your vehicle. There are issues. I would recommend either 3.4.21265 or the latest 3.4.23188, with the latest maps.
Based on your vehicle and your desire to upgrade to Sync 3.4, you could use these autoinstall.lst and reformat.lst files.
reformat.lst (657 Bytes)
autoinstall.lst (149 Bytes)
Download the reformat file and all of the files listed in the reformat file and place them in the SyncMyRide folder on the USB.
I’m still having the same issue with build 3.4.21265 or the latest 3.4.23188
VOICE=5U5T-14G391-CP_1626959995000.TAR.GZ
If you want 3.4.21265 change these lines in the reformat file above and download these files.
Don’t I need the individual maps files to keep my maps… or update them? or do i just need the reformat file and autoinstall you’ve provided?
You need all the files listed in those docs…
Fixed…
Worked flawlessly. No issues whatsoever to report so far.
