No navigational voice prompts in unit bought off eBay
I have a 2013 F150 that I upgraded the sync 2 to a sync 3 system that I bought off eBay. Everything works perfectly except I don’t have any voice prompts in navigation. This is in both the unit maps and in Android Auto in Waze, and Google Maps. I have been messaging the seller and they can’t help me. I’ve done a master reset with no help. Below is my Interrogator Log. Any suggestions?
VIN: 1FTFW1CF3DKE8XXXX
APIM Model: Unknown
APIM Type: Navigation
APIM Size: 32GB
APIM Free Space: 3.7G
Version 3.4.23188 (NU5T-14G381-AD)
11/12/2024 6:59:38 PM +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 12M / 1.6G
/fs/sd/MAP/ = 12M / 1.5G
/fs/sd/MAP/ = 10M / 1.5G
/fs/sd/MAP/ = 3.1M / 1003M
/fs/sd/MAP/ = 8.3M / 1.3G
/fs/sd/MAP/ = 14M / 1.8G
/fs/sd/MAP/ = 17M / 1.7G
/fs/sd/MAP/ = 6.4M / 1.3G
/fs/Nuance/ = 16M / 1.7G
/fs/Nuance/ = 10M / 1.1G
/fs/Nuance/ = 23M / 2.5G
/fs/Nuance/ = 3.2M / 465M
/fs/rwdata/ = 926M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 83M / 1.4G
/fs/images/ = 3.7G / 25G
Installed Packages
4U5T-14G421-CJG
4U5T-14G421-CHG
4U5T-14G421-CGG
4U5T-14G421-CFG
4U5T-14G421-CEG
4U5T-14G421-CDG
4U5T-14G421-CCG
4U5T-14G421-CBG
4U5T-14G421-CAG
5U5T-14G391-CS
4U5T-14G422-CCN
4U5T-14G422-CBN
4U5T-14G422-CAN
4U5T-14G423-CC
APIM AsBuilt
DE00: BLANK
DE01: BLANK
DE02: BLANK
DE03: BLANK
DE04: BLANK
DE05: BLANK
DE06: BLANK
Install Type: Unknown
Old SYNC Version: 3.4.23188
Did you check the NAV setting to see if you have NAV voice prompts turned on?
Do Google Maps voice prompts work if the app if just running on your phone and not connected to the car?
Yes, I turned on the voice prompts in the NAV settings. They also work in Waze and Google Maps on my phone. I’ve tried turning up the volume when the NAV prompts are supposed to be playing and that didn’t help.
Sounds like a bad or missing voice package in the Sync install.
Likely missing a voice package, but you can verify that with the Interrogator utility. If you have a Sony radio system in the truck you will need to make sure it is configured properly in the asbuilt, and vice versa. Nav prompts use a separate channel in the ACM, like the rear backup alarm does. The ACM routes and embeds the nav prompts, etc., accordingly.
Thanks for responding. I have the Sony system and posted my Interrogator log file results in my first post above so it looks like I have all of the files as far as I can tell. I’ll look into the AsBuilt configuration. The Syns 3 has more memory options in the ACM module so I’ll have to figure out the lines. I compared my ACM values from my Sync 2 to Sync 3, which are the same.
Audio Control Module
Module Current Settings
727-01-01 12A0 D000 00B2
727-01-02 0031
727-02-01 5B8C
727-03-01 1446
727-04-01 0001 0255 53DE
Since the unit is up and running, go into bezel diagnostics and find the APIM model (it has 14G371 in the middle)
Your ACM asbuilt is fine except if you are using SDARS. Should be 727-04-01 0001 0155 53DD.
Your files loaded on your APIM are correct.
Post you APIM asbuilt so we can look at it.
Also, try turning up the volume during a nav prompt as this is separate from the main volume.
Here’s my Bezel Diagnostics
Thank you for the images, it’s blank as well… I’m used to seeing it being blank in the interrogator output, but not in the bezel diagnostics…
You can’t really trust stuff bought on eBay…
The APIM is questionable as far as authenticity, as @SaNdMaN suggests. If you can find a part number for the unit it would help.
Here’s the APIM number. I couldn’t find a number on the screen.
I appreciate you guys taking the time to help me.
No good, for 2 reasons:
  • that sticker looks fake to me
  • the model is the assembly, not the APIM’s
Either way, I can now be pretty sure the unit is a counterfeit.
I echo what Sandman said. All this talk though and you still have not done what F150Chief said to do.
