Park Aid & Sensors Not Working
Right, im hoping someone can help
Ive recently bought a 2014 C-Max 2.0 diesel, automatic, which i was aware the above were not working.
Ive plugged in with forscan and im getting the following DTCs
Code: U0159 - Lost Communication With Parking Assist Control M
Status (-0A):
  • DTC Present at Time of Request
  • Malfunction Indicator Lamp is Off for this DTC
Module: Power Steering Control Module
Freeze Frame #1:
  • EVENT_TIME: 333751905 s (Sat Jun 14 19:08:53 2025) - Event tim
  • TOTAL_DISTANCE: 64647 km - Total Distance
  • MODULE_VOLTAGE: 11.8 V - Control Module Voltage
  • OUTDOOR_TEMPERATURE: 17 °C - Outside temperature
PWR_MODE_KEY: Ignition On - Power Mode Key State
  • PWR_MODE_QF: Power Mode OK - Power Mode Quality Factor
  • SS_TRQ2: -0.5 Nm - Steering Shaft Torque 2
  • ECU_POWER_SUPPLY: 12.0 V - ECU Power Supply Voltage
  • ECU
    _INTERNAL_TEMPERATURE: 20 °C - ECU Internal Temperature
  • VS3: 0.0 km/h - Vehicle Speed
  • DLA_SED_FDOB_PID: 129 - DL_SED_FDOB_PID
  • DLA_NUM_FDOC_PID: -0.02 A - DL_NUM_FDOC_PID
  • DLA_NUM_FDOD_PID: 0.00 A - DL_NUM_FDOD_FID
  • DLA_NUM_FDOE_PID_1: 0.0 Nm - DL_NUM_FDOE_PID_1
  • DLA_NUM_FDOF_PID_1: 0 1/min - DL_NUM_FDOF_PID_1
I also have a similar message for the rear camera.
The original build sheet, show the car left the factory with above options.
It has the 10 sensor park aid.
When in forscan i cannot find build date in the AsBuilds for both the camera and the pam.
I have
7A5-01-01 00AE
720-02-01 FFFE FFFF 43
Am i right in thinking, that the BCM is not actually programmed to find the said modules?
Any help appreciated
Here is my build sheet
||7A5-01-01 |00AE
| |7D0-01-01 |111F |89C0 |0355 |
| |7D0-01-02 |4000 |001A | |
| |7D0-02-01 |0455 |4B00 |007E |
| |7D0-02-02 |00DB | | |
| |7D0-03-01 |0000 |0000 |00DB |
| |720-20-01 |FFFE |FFFF |43 |
| |726-01-01 |5400 |8104 |A2AA |
| |726-01-02 |0100 |0014 |0A4F |
| |726-01-03 |4150 |1201 |10E5 |
| |726-01-04 |0101 |0202 |053D |
| |726-01-05 |1800 |000B |0B61 |
| |726-01-06 |00C0 |0100 |00F5 |
| |726-01-07 |0000 |7D00 |00B2 |
| |726-01-08 |0000 |0000 |0036 |
| |726-01-09 |0000 |0000 |0037 |
| |726-01-10 |0000 |0000 |003E |
| |726-02-01 |0004 |1E1E |70 |
| |726-03-01 |0101 |33 | |
| |726-04-01 |0100 |33 | |
| |726-05-01 |0033 | | |
| |726-06-01 |0034 | | |
| |737-01-01 |0040 | | |
| |737-02-01 |8000 |0000 |C1 |
Looks like you may have a bad steering module.
I would guess the same. 7A5 is not your rear camera, it is your Navigation Display MFD5. Because you have a 2014, the camera has no own Module and is controlled by the BCM, by its own LIN line. A module doesn´t need to be programmed to only be find. Either a module on your HS-Can is defect or the wiring is messed up. The PAM has no own AsBuilt.
