Hello,
I try to upgrade my apim module to 3.4 to the newest version with new maps F11. But I have problem with extracting map package. Now is 1h when I started update but nothing happened the extraxting bar is sttandig still and I thing extracting stops. I did the last time upgrade and everything goes fine. My previous update to 3.4 and had maps F10.
Please for advice what to do?
If you are using a potato USB, that might be the issue.
It’s hard to say more without seeing the log, which can be found on the computer used to create the USB.
I’m using the same USB as in previous update.
I restart instalation and see what happened now. If not help I create new USB.
After restart instalation everything is fine. Update complete. Thanks for help.
I close topic.
