Problem With update Ford Sync 3 F12 Maps
Hello, I’ve problem with my Ford Kuga Sync 3 system. I’ve update to sync 3 version 3.4-23188 successfully. After I tried to install F12 update maps, but when I tried to Update it, I get messagge error MEM_ERR01. I’ve tried more time to update it, but I have only same error. You can help me? Under there is XML file who is generated from Syn3Updater. Thanks
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<p:OTAModuleSnapShot xmlns:d2p1=“urn:ford/Vehicle/Module/Information/v3.0” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:p=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0” version=“2024-10-07” xsi:schemaLocation=“urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd”>
<p:VIN>XXX</p:VIN>
<p:RequestRole>
d2p1:RoleCONSUMER</d2p1:Role>
d2p1:RoleDescSYNCGEN3</d2p1:RoleDesc>
d2p1:RoleIDOTA</d2p1:RoleID>
</p:RequestRole>
<p:BroadcastDTCType/>
<d2p1:ECUAcronym name=“APIM”>
d2p1:State
d2p1:ResponseNU5T-14G381-AD</d2p1:Response>
</d2p1:DID>
d2p1:Response315535542d3134473432312d424147000000000000000000315535542d3134473432312d424247000000000000000000315535542d3134473432312d424347000000000000000000315535542d3134473432312d424447000000000000000000315535542d3134473432312d424547000000000000000000315535542d3134473432312d424647000000000000000000315535542d3134473432312d424747000000000000000000315535542d3134473432312d424847000000000000000000315535542d3134473432312d424a47000000000000000000315535542d3134473635382d414800000000000000000000315535542d3134473432342d424d00000000000000000000345535542d3134473432332d414300000000000000000000355535542d3134473339312d415400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
d2p1:Response00490caf</d2p1:Response>
</d2p1:DID>
d2p1:Responsed287f2a4</d2p1:Response>
</d2p1:DID>
d2p1:Response0a6a019a50027e440082</d2p1:Response>
</d2p1:DID>
d2p1:Response4954010ef60a5c90acb4ce05</d2p1:Response>
</d2p1:DID>
d2p1:Response0007000000</d2p1:Response>
</d2p1:DID>
d2p1:Response00000c80250107</d2p1:Response>
</d2p1:DID>
d2p1:Response18061810295f</d2p1:Response>
</d2p1:DID>
d2p1:Response20</d2p1:Response>
</d2p1:DID>
d2p1:Response17003a00000000a17500005656780088</d2p1:Response>
</d2p1:DID>
d2p1:ResponseDS-1U5T-14G371-EK</d2p1:Response>
</d2p1:DID>
d2p1:ResponseGU5T-14G380-FE</d2p1:Response>
</d2p1:DID>
d2p1:ResponseLU5T-14G371-GMF</d2p1:Response>
</d2p1:DID>
d2p1:Response1U5T-14G375-HA</d2p1:Response>
</d2p1:DID>
d2p1:ResponseNZ8H00QX</d2p1:Response>
</d2p1:DID>
d2p1:ResponseBlank</d2p1:Response>
</d2p1:DID>
d2p1:Response03</d2p1:Response>
</d2p1:DID>
d2p1:Response1U5T-14G374-EK</d2p1:Response>
</d2p1:DID>
d2p1:Response/
</d2p1:DID>
d2p1:Response10:08:2c:b9:4e:63</d2p1:Response>
</d2p1:DID>
d2p1:Response10:08:2c:b9:4e:64</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime=“2024-10-07T10:35:00+00:00” RAM=“1006804992” vmcuVersion=“Vector_VMCU_05.04.25”>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.1G” available=“676K”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.9G” available=“15M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.7G” available=“16M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.4G” available=“14M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.4G” available=“16M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.5G” available=“7.6M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.5G” available=“9.3M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.3G” available=“17M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.2G” available=“18M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.7G” available=“24M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“38M” available=“308K”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.3G” available=“4.5M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.2G” available=“8.4M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.2G” available=“26M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.6G” available=“29M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“1.9G” available=“8.4M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/grace” total=“1003M” available=“21M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/” total=“1.2G” available=“837M”/>
<d2p1:PartitionHealth type=“/fs/mp/resources” total=“72M” available=“332K”/>
<d2p1:PartitionHealth type=“/fs/images/” total=“54G” available=“13G”/>
d2p1:InstallationLog/
d2p1: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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Old SYNC Version: 3.4.23188
New SYNC Version: 3.4.2388
MEM_ERR01
What year Kuga?
Were you using an official map update downloaded from Ford using your VIN?
Yes, offical Ford site with VIN. I’ve tries also syn3 Update, but I saw MEM_ERR01.
I would start with:
  1. Make sure you are using a good quality USB (San Disk, Lexar, PNY) formatted as exFat
  2. Make sure nothing else even a charging cable is plugged into the other USB
  3. Try the other USB on the off chance you have a flaky port
There is only one usb port, another is usb-c port. I’ve used sandisk 64 gb usb key. Error persist
Share the XML file instead of a copy&paste
You can use a USB C to USB A convertor
My XML file is in the first post
I’ve tried another usb, but it display MEM_ERR01
