Proper writing procedure for sync4
When making edits in forscsn do I need to write after each edit and let the truck sleep then edit the next line and sleep the truck. Sleep meaning write, shut off truck open and close door then turning on again and write the next line. So on and so forth.
Or can I edit all the lines at once and do a write all then sleep the truck. I read somewhere the sync4 is different from sync3. I have knowledge of sync 3 with forscan not sync4.
Were not Forscan but I can tell you from my own experiance that you can write all at once and you dont need to reset anything between each write. If there is an error though do to a bad setting than you may not know where that is at.
Pro tip though is make sure to save your AB info before you start messing with stuff in case you need to revert back.
You can write all at once. Best way to do your edits is use easy mode (not the as-built) under each module. It’ll have everything in a list for you to see, without worrying about changing blocks.
These are not always correct. I have had many of these be wrong and I have had to manually change them to get a correct setting.
Easier for sure though.
This is actually not the case in respect to double-byte asbuilt coding found in some settings or modules. Although the majority of settings are related to single-byte changes, which the ‘easy mode’ works fine, the double-byte settings can influence up to 8 different features with up to 4 different states. Easy to make a mistake, that is why we recommend to use the asbuilt editor, not the drop downs.
