Hi,
I’ve been tasked with reading data from a navigation system in a 2020 Ford Ranger and need to be able to get it up and running in the lab. From what I’ve found, I’ll need a CAN bus simulator that generates the necessary wake-up signals. Can anyone recommend a set of cables for a workbench setup (commercial, not DIY)?
I think it has to fit in connector 4. It has to provide a suitable power supply then , I think.
Type of Car is:
Ford Ranger Typ „2AB" „YN2X4P" „51DBAQV4"
Accessory Protocol Interface Module (APIM) Modell14G370
Can anyone confirm that Connector 5 is a USB Port. I would need a cable for this then, too.
Then at the end, when I can get the unit running on a workbench, I will have to get access to the Memory. As far as I know, it should be a QNX/Linux/Android OS, and it may contain the last 40 navigation destination including the date and timestamps. And this would be very important: We need some evidence that the destination address which was entered in the system has been reached at a specific date/time.
I would really appreciate any further tips. Best regards from Germany.
Thomas
