Replacement ACM
MY19 Lincoln Continental fitted with Chinese market audio and a Revel 19 speaker system. I live in the UK.
My problem is that It works fine but has no DAB nor has the FM got RDS or TA although strangely it does display Radio Text [the track or info the FM station is playing].
Factory ACM is GD9T-18D818-BU with the blue A2B socket for Revel system.
I have tried fitting an ACM from a UK Mondeo: JS7T-18D818-JA, and the DAB worked, as did the TA and even roadworks info was displayed on the Sat-Nav but as it had no A2B socket, no sound.
The European Ford Fiesta Titanium model has the ACM: H1BT-18C815-ZK with a A2B socket but has the 64 pin pinout rather than the
24 and 26 pin pinouts.
I feel there’s not a simple solution, and if there is a complicated solution it will be expensive.
You need a EU 2019+ Lincoln ACM (not sure if a Ford “Sony” will work).
In the US the Sony ACM was A2B in most models beginning with the 2017MY.
DAB & RDS are region specific, some parts of the world have them and some don’t, so models will have capabilities based on the market the car was delivered to when new.
