Request for ABS As-Built Digital Twin – BV61-2C405-AF
Hello CyanLabs community,
I’m new here and I’m looking for some technical help.
I have a 2011 Ford C-Max 1.6 TDCi Titanium with ABS module BV61-2C405-AF. Unfortunately, the ABS As-Built data was erased, and Motorcraft does not provide it for my vehicle.
I’m looking for a digital twin: either a VIN or an ABS As-Built export from a 2011–2013 Ford C-Max or 2011–2012 Ford Focus equipped with the same ABS module (BV61-2C405-AF).
If I can get just a VIN with the same ABS module, I can retrieve the As-Built myself from Motorcraft. Any help or guidance would be greatly appreciated!
Thanks a lot in advance for your support, and sorry if this seems like a basic question – I’m new here.
Best regards,
PM me your VIN…
Hi @F150Chief,
Thank you again for offering your help with my ABS issue. I’d like to send you my VIN via private message, but I don’t yet see the option to send a DM. Would it be possible for you (or a moderator) to enable private messaging for my account?
I really appreciate your assistance — thank you!
See if you can do them now.
Thanks
The ABS in the pre facelift modules is not programmed thru As-Built. It takes its settings from Central Configuration via the BCM. Mine shows all zeros. However, if you put a diffrent setting in from a facelift car, it is possible that you can´t erase this setting.
1ftew1eg3hfa32515
