I recently retrofitted my Ford Fusion 2013 AWD 2.0 Ecoboost Gasoline, installed the instrument panel (IPC) of the Ford Mustang GT 5.0 2018. Everything worked as it should, but I was missing an important function that I had on my instrument panel previous, TSR (Traffic Sign Recognition), the option exists to be enabled, however, it does not work (I tried using UCDS and FORSCAN). I believe that because the Mustang does not come with this functionality from the factory, the option is locked directly in the EEPROM. So, I did the DUMP of the EEPROM to analyze, but I really don’t know where to start. Does anyone have any idea how to find the responsible blocks in the EEPROM to edit and enable the use of the TSR?
The Mustang IPC does not support TSR in production, therefore there is no calibration file for the Mustang IPC to do what you want.
