Retrofit pre collision Fiesta st mk8.5
Hi,
I have a question I bought a camera for in the front window to do pre collision retrofit now I have camera with H1BT-19H406-CA current camera/IPMA is L1BT-19H406-BG. Will this cause problems with matrix led headlights or does that not matter! Thanks in advance
Hi, did you manage to do this retrofit ?
I’ve done mine too but I can’t tell if it’s working or not.
I fitted the bi directional abs sensors (same on both sides) changed the camera for a C* model. Enabled pre collision assist in abs, ipma and ipc etc where needed, I get the red flash box on screen warning with the beeping but car doesn’t seem to slow down.
Any tips / suggestions if you managed to get it working ok?
Yes I did and worked perfect even the braking when you dont take ure fooT off the gas or brake! Try Bcm low speed mitigation I think and enabled it and in youre APIM or IPC where youre menu is and enable emergency brake assist or something like that
What year is your car?
I enabled low speed mitigation and still no active brake assist. Im wondering if its because mine is an older car, this thread is for the 8.5 so perhaps i dont have the correct ABS modules or something, on the 2019+ cars you can enable different traction modes like Snow, rain, trail etc. on my module i dont have the 760-03 section which is whats used to enabled the modes.
I have read on other forums it can be retrofitted on to older models too so im probably just grasping at straws as to why mine doesn’t work.
