You will need to adjust the APIM asbuilt with FORScan and an OBD adapter. You will need to disable the DSP.
This will be the first line of the asbuilt. At the position noted, you will change the value to 0.
7D0-01-01 Xxxx xxxx xxxx
0=DSP Disabled, AAM Disabled, SDARS Disabled, Rear Seat Entertainment Disabled
1=DSP Disabled, AAM Disabled, SDARS Disabled, Rear Seat Entertainment Enabled
2=DSP Disabled, AAM Disabled, SDARS Enabled, Rear Seat Entertainment Disabled
3=DSP Disabled, AAM Disabled, SDARS Enabled, Rear Seat Entertainment Enabled
4=DSP Disabled, AAM Enabled, SDARS Disabled, Rear Seat Entertainment Disabled
5=DSP Disabled, AAM Enabled, SDARS Disabled, Rear Seat Entertainment Enabled
6=DSP Disabled, AAM Enabled, SDARS Enabled, Rear Seat Entertainment Disabled
7=DSP Disabled, AAM Enabled, SDARS Enabled, Rear Seat Entertainment Enabled
8=DSP Enabled, AAM Disabled, SDARS Disabled, Rear Seat Entertainment Disabled
9=DSP Enabled, AAM Disabled, SDARS Disabled, Rear Seat Entertainment Enabled
A=DSP Enabled, AAM Disabled, SDARS Enabled, Rear Seat Entertainment Disabled
B=DSP Enabled, AAM Disabled, SDARS Enabled, Rear Seat Entertainment Enabled
C=DSP Enabled, AAM Enabled, SDARS Disabled, Rear Seat Entertainment Disabled
D=DSP Enabled, AAM Enabled, SDARS Disabled, Rear Seat Entertainment Enabled
E=DSP Enabled, AAM Enabled, SDARS Enabled, Rear Seat Entertainment Disabled
F=DSP Enabled, AAM Enabled, SDARS Enabled, Rear Seat Entertainment Enabled
