Screen not turning off
I have tried the following butt no success . It stays lit for around a hour then go’s off completely
Car Battery Dies Quickly / APIM Doesn’t Seem To Turn Off When The Car Is Off
If you are having issues where the APIM doesn’t turn off after the car ignition is off and door opened.
In ForScan set the APIM As-Built 7D0-06-01: x1xx-xx
You are missing the last sentence of the actions to take. Re read the FAQ and check your settings, there’s something else you need to verify/change.
Screen isn’t turning off when car powered off
If you are having issues where the APIM doesn’t turn off after the car ignition is off and door opened:
In UCDS set the APIM DEO5 > “illumination Gateway” to C1MCA
Huh? thats 2 different ways of doing it, 1. using ForScan or 2. using UCDS
Oh ok, I was under the impression there where 2 separate things.
Maybe he should post his asbuilt then.
Have you master reset?.
Yeah i agree, post your asbuilt @bishbashbosh09
will do later . cheers
Hi sorry its taken so long i was at work when you was replying
nonav apim01.abt (401 Bytes)
Is this the original asbuilt for the APIM or has it been edited? Or is this a retrofit?
The clock master is incorrect for the vehicle type. 2016 is a BCM Master Clock, not the APIM. It looks like the APIM asbuilt was edited and the values are misplaced in 7D0-01-01.
its a retro fit and i hve tried to edit it :scream:
Thanks for the quick answer. Did it have Sync 1? The small 4" screen…
no problem thank you for your quick reply . yes it did
OK, so we have a 2016 Transit Connect in UK with a retrofitted Sunc 3 from Sync 1. Give me a little while and I’ll post a new asbuilt for you to try a bit later.
great stuff thank you :relaxed::+1:t2:
2016 transit connect UK
See your PM…
yes retro fitted sync 1 to sync 3
how do i do that ? sorry
Left side bar “Messages”.
Reply to the message I sent.
ok done it cheers
Check your PM, I uploaded a new APIM asbuilt for you…
thank you really appreciate your help . i will give it a go 2moro and let you know .
Thanks again :wink:
