Only thing left I can think of would be to got to the ACM and zero out the presets:
All of 727-05-01, 727-06-01. 727-07-01, 727-08-01
Then once those are cleared and saved, do a master reset of the APIM.
Well, this is strange:
I cleared the presets from the ACM, did master reset to the APIM. For some time the presets were empty, but when I started tuning somehow the old presets came back
together with the same logo misery.
After the master reset did the ACM values repopulate?
When I had something like this with Sirius logos, the final solution for the problem was to drop another APIM in my car with my factory AB left it in for a day.
After that I saw the right logos on that APIM, then I put my original back in and it showed them as well.
There has to be a hex identifier for the logo saved somewhere that matches to the station, just like putting a custom icon on a Windows shortcut. Move the icon file or replace it with another file that has the same name and you lose the custom icon.
Hi,
Finally success. I found the cause of the issue and I was able to solve it:
The database that matches the logos to the stations is outdated. It contains wrong station ids and frequencies. I corrected most of it, so now it looks much better, I have most of the logos. ![]()
Thank you for your efforts!
What file was the db and what was the process to correct it?
I’m having the same problem so I’m also interested in the solution and how to resolve the issues with missing logos.
OK, here’s the process in brief:
I have tried to connect to APIM with SSH Acess but i gets stuck with username and password. Cant find that information anyware.
The logon procedure is documented over the FMods’ thread referenced before… ![]()
got it working after some head scratching ![]()
Update:
