Syn3 Updater 2.14.20 can't identify APIM from Interrogator XML (SYNC 2.3.17109)
Hi @SaNdMaN,
I’m trying to update my 2018 EU Ford Transit Custom (factory navigation) from SYNC 3.0/2.3.17109 to SYNC 3.4 using Syn3 Updater 2.14.20 Stable.
The Interrogator creates an XML successfully, but Syn3 Updater reports:
“Selected XML file does not contain expected output. Syn3 Updater determined you are on 2.3.17109 and may be using non-standard builds. Unable to determine your APIM configuration.”
As far as I know, my APIM is original. CarPlay worked in the past but has stopped working recently.
Could you please have a look at my Interrogator XML and tell me:
  1. Does the XML indicate a non-standard or corrupted installation?
  2. Why can’t Syn3 Updater identify my APIM?
  3. Is there a recommended manual update path to 3.4, or should I first install a specific APPS package?
I’ve attached the complete Interrogator XML.
Thanks!
Sync_NX430262_WF0ZXXTTGZJT75130.xml (9.8 KB)
