still present on audible USB mp3 files and streaming Spotify via bluetooth
still present (only checked USB mp3)
There are some reports about this build having issues with aftermarket cameras (not Fordâs): the picture loose quality and also itâs in black and white.
If you have this issue, all you need to do is downgrading to 3.4.21098 and the camera will work just fine, as before.
This is a common sign of NTSC/PAL signalling. it happened in old school TVâs back in the day.
I just successfully upgraded from 3.4.21098 to 3.4.21194 without any problems.
Thank you!
Ford Focus Turnier 1.0 Ecoboost Titanium, 2017
That was my dayâŚ!
Updated my UK 2017 fiesta Ecoboost today without issues. Thank you again Cyanlabs.
Interesting one. Looking to upgrade a vehicle from 3.0.20092 to 3.4.21194 with maps (ver 2.20) for Australia. Regardless of whether I click START or Download, it gets part way through, downloading files with out issue and then comes across one file which it then prompts the error (red box) saying âERROR - The file is too long. This operation is currently limited to supporting files less than 2 gigabytes in size.â The operation then stops. The file it has the issue with is 4U5T-14G421-DAF_1615429515000.TAR.GZ
Any thoughtsâŚ
Correction: itâs due to the number of connections you are using.
This is the bad line of code, filesize / download connections = xxxGB parts
In regards to this specific file
4.92GB
If you was to do 2 connections for this file that would result in ~2.5GB files which is higher than the allowed 2GB of that function.
Thanks - I had two connections selected on this computer when it failed. Interestingly the other computer only had one connection and it downloaded fine.
Yes itâs a bug, added to the issue tracker, but unlikely to be fixed in v2.x as iâm currently rewriting v3 from scratch. the solution is to ensure that filesize / connections doesnât equal more than 2GB, so 4.5gb / 2 = 2.25GB which is too big, best to just use either 1 connection or 4.
5 posts were split to a new topic: 3.4.21194 Camera Issues
Hi,
I still have the flickering issue with this version - Ford Focus RS (2016).
Friends,
We have a problem to update an APIM central in 2 cars (FORD EDGE 2014 and FORD RANGER 2017) we are in Brazil and in the ANZ version (includes the SA=BRAZIL translation) the language translated to PT-BR
is not showing. we have already done 3 times for version 3.3.19052 and up to 3.4.21194 and there is no language option in Portuguese.
thank you for helping
You probably have the 5U5T-14G391-AP Sync Voice file loaded in both cars, which does not contain PTB - Brazilian Portuguese language. You will need to load a region specific voice file:
5U5T-14G391-DP_1626960105000.TAR.GZ
1.0Gb Sync3 v3.2.21169
ENA, ENG, ENU, GED, MNT, PTB, RUR, SPM, TRT
Follow the instructions below:
- Create a USB drive (format as EXFAT) with a SyncMyRide folder.
- Copy the file downloaded above into the SyncMyRide folder.
- In the root of the USB is the autoinstall.lst and DONTINDX.MSA files which you can obtain from any upgrade you previously performed.
- You will need to edit the autoinstall.lst file so it looks like the example below.
Item1 = 5U5T-14G391-DP_1626960105000.TAR.GZ
Open1 = SyncMyRide\5U5T-14G391-DP_1626960105000.TAR.GZ
Options = Autoinstall
- Insert USB in vehicle and wait for the installation to complete. You should see a message indicating completion.
- Remove the USB drive and reboot the APIM.
All the files needed can be found at the Software Database - CyanLabs
Darling the shot was in the can!
problem solved!
thankful
Received an OTA update for the Kuga MY21 yesterday and it seems that the USB music playback issue has been resolved, so far everything sounds fine.
Interesting and potentially great news. What version did you end up with after the update? Is it different from the one in this topic?
Thanks.
There is no newer version than this currently.
Updated a week ago to 21194 with F10 maps. Everything works fine
I had an issue with previous 3.3 and 3.4 versions with voices in German even after selecting Spanish, EnglishâŚFixed this issue by selecting region as America and Canada even though I live in Spain. System said it was not going to work but it really did in my 2015 Ford Mustang.
