Hello, I have installed sync 3.4 from sync 3 a long time ago. I am in Greece.
It works smoothly but when I press “stations” to find FM radio I have the loading circle and nothing happens, it doesn’t show me anything.
What should I do?
If needed to do something with forscan I have an obd adapter
Thanks
Did you do a master reset after the upload to the car?
Yes I tried 2-3 times
Have you made any changes with Forscan?
No I didn’t change anything. But if you know what I have to change I have access ![]()
stations are not controlled by the APIM, check for errors in forscan/ucds specially for the ACM
Last time I checked forscan I had no errors but I will check the acm as you said. Thanks a lot
Is the car a NA import or is this an EU vehicle?
You’ve had sync 3.4 for ages and this is only now an issue or has it always been an issue?
The car is EU. I bought it in Greece and it was in Italy before
It is sync 3.4 updated from sync 3.0 and I had this issue from the beginning
