Sync 3 Ambient Lighting & Clock not working after updating to lastest 3.4 on here
This is why the clock and ambient lighting are not working. And probably why you have the ABS error.
Master Reset the APIM. Once that is done, load the ORIGINAL ASBUILT back into the APIM using FORScan and the ‘Load All’ button at the bottom of the asbuilt configuration screen. Once that is loaded and reboots, perform another Master Reset on the APIM and clear the DTC’s manually.
